1977 positraction ?
Old Feb 12, 2003 | 06:59 PM
New-Zealander's Avatar
New-Zealander
Default 1977 positraction ?
i have a 1977 vette that wheel spins only the right rear tyre,is this normal ?arent 77`s meant to have positraction which should eliminate one wheel spinning ? :crazy:
Old Feb 12, 2003 | 07:12 PM
flood's Avatar
flood
Default Re: 1977 positraction ? (New-Zealander)
yeah, both should be a' spinnin :eek:
bad posi unit? check the fluid in the diff
Old Feb 12, 2003 | 08:08 PM
Gordonm's Avatar
Gordonm
Default Re: 1977 positraction ? (flood)
If only one is spinning most likely the clutch pack is gone. Time for a rebuild
Old Feb 13, 2003 | 01:25 AM
New-Zealander
Default Re: 1977 positraction ? (Gordonm)
Thanks for your help guys, much appreciated :cheers:
Old Feb 13, 2003 | 01:47 AM
Chris O''s Avatar
Chris O'
I'd replace the fluid 1st - cheaper than a rebuild!
:cheers:
To 1977 positraction ?
