Getting the gauge cluster even.
Old May 9, 2025 | 03:22 PM
ETRADIO's Avatar
ETRADIO
Default Getting the gauge cluster even.
1975 C3 Coupe
I know a lot of you have seen this, at the top of the gauge cluster where it meets the dash for some odd reason one side always sticks out further toward the driver than the other side. Has anyone figured out how to make that straight across? I’m doing my best to figure this out and I just can’t get to the bottom of it. Here’s a picture of what I’m talking about. Look at the top of the top left sticks out toward the driver. If anyone here knows the fix for this please let me know so I can stop banging my head against the garage door.
Thanks in advance,
Powe.
Old May 9, 2025 | 03:49 PM
Tuna Joe's Avatar
Tuna Joe
That’s the way it was built from the factory.
Old May 9, 2025 | 06:51 PM
Artey's Avatar
Artey
My 72 is like that, though not to that extreme. I tried like hell to get it better with very little success.
Old May 9, 2025 | 08:22 PM
kansas123's Avatar
kansas123
My 72 isn't perfect but pretty good. Seems to me there is a screw that goes up thru the top of the piece that if you push the frame up and then tighten the screw tight, it might help. I know you shouldn't do a lot of monkeying around with the piece because it can be broken at the weak points so you have to be careful. It really wasn't designed very well, some were not very good even when new. Make sure nothing behind it is getting the way also.
Old May 9, 2025 | 08:51 PM
ETRADIO's Avatar
ETRADIO
Hey,
‘Thanks for the tips, I’ve really tightened things up behind it, it seems the that the way the console clips hit the studs make it pull to one side when you try to line it up, I’m going to do some modifications on it Tomorrow, After I layed that insulation down, it didn’t help matters, I’m going to split the plastic inseams of the console and butterfly the ends, then I’m going to ream out the slots where the studs go so the threads stop getting caught on the mounting plate. Then I’m going to straighten it up and mount it to the sides of the two side dash panels. After I split the inseam on the console, I’ll take it and get the fit, then I’ll take my instant plastic and remold and seal the cracks in place, then put the console back in. I just went into the garage and cracked the inseams on the console, it appears that this will work very well. I’ll post some pics later, Thanks again,
Powe.
Old May 9, 2025 | 09:32 PM
teedoff65's Avatar
teedoff65
Originally Posted by ETRADIO
Hey,
Powe.
Ibterested in what you do to fix this. My 72 is like this as well. I assume it was warped since its plastic or that there was a screw or something behind the left side keeping it from being flush.
Old May 10, 2025 | 04:39 PM
ETRADIO's Avatar
ETRADIO
Default UPDATE : Getting the Gauge Cluster Even
today was the day that I cracked the center console and reformed the way it sits in the car. I’ve included some pictures on what I use and how I do this process. If you use this type of plastic, make sure you use P100 filters and a mask… the fumes from this stuff will knock you completely out, that’s why I highly suggest you use P100 filters with a professional mask. When as it cures it hardens into the plastic, becoming part of the original material, it’s tough as steel, “Almost.” it only takes 15 minutes to fully cure. Things are coming together really well, the reason the bezel tilts out is because the screw position in the top of the dash is slightly off, some cars have it some cars don’t, apparently it comes from the factory like this. But I have a fix… as soon as I get it all put together I’ll include the pictures, below some pics of what I used to fix the center console after I cracked it and reformed it.
Old May 11, 2025 | 09:47 AM
Eliredandblack's Avatar
Eliredandblack
You are lucky, the center console can be repaired. I bought a new pot metal center gauge and didn’t like the way it fit, exactly like the op picture. Unfortunately, I keep f_ king with it until I broke the thin metal vertical side. Let’s face it, the original fitment of these cars was not GREAT, and after 50 plus years, all parts (plastic, fiberglass, pot metal etc.) are obviously warped or bent from age/heat.
Old May 11, 2025 | 10:26 AM
Zanny1's Avatar
Zanny1
Seems to be a common problem. My 1975 original low mile car.... and yes, the center instrument panel is cocked with left side higher than the right side. Build quality on these cars is something to behold.
Annoying, but I'm not going to make an attempt to fix it.
Old May 11, 2025 | 11:31 AM
pltmgr's Avatar
pltmgr
Endless fitting of C3 consoles will be my special punishment in hell.
Old May 11, 2025 | 12:08 PM
ETRADIO's Avatar
ETRADIO
So true!!!! lol
To Getting the gauge cluster even.
