Crossfire issues
Old May 22, 2025 | 05:09 PM
jjford129@icloud.com's Avatar
Default Crossfire issues
My 1982 corvette with crossfire injection cut out on me the other day on the road, had it towed home and this morning ran for about 2 blocks then cut out again. The fuel pump is working and the injectors are firing, but it doesnt fire up, just cranks. Any ideas?
Old May 22, 2025 | 11:30 PM
MelWff's Avatar
MelWff
Did you pull a spark plug boot, insert a screw driver in the boot, hold the metal part of screw driver near metal and have someone try to start to check for spark?
If you have a timing light you can use that to test.
Old May 23, 2025 | 04:45 AM
Carnut63's Avatar
Carnut63
Ignition module. Main battery ground. Coil.
Old May 23, 2025 | 05:15 AM
Ahrmike's Avatar
Ahrmike
definitely sounds ignition related if youre getting fuel. ICM (little plug thing in the distributor) seems to be a common issue. That or the ignition coil, maybe? You can also unplug the anti-theft and see if it works.
Old May 23, 2025 | 11:24 AM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
The first thing you absolutely need for any CFI car is the 82 GM service manual that you can find usually on eBay. It has everything you need to find, fix and maintain your CFI system. Follow the troubleshooting charts and you will find the issue and it does sound like an ignition issue. GL
Old May 23, 2025 | 11:40 AM
Eric P's Avatar
Eric P
Check spark at the plug wire , the injectors firing indicates the module is working good enough to it least fire the injectors during crank mode, sometimes those distributor rotors burn through the center and the spark goes to the distributor shaft instead of the plug wire , if no spark at the wire then remove distributor rotor and inspecting the back side of the rotor for a big black burn spot
Old May 23, 2025 | 03:21 PM
TKX 5-SPEED C3's Avatar
TKX 5-SPEED C3
Listen to Tom, he knows a couple of things about '82's.
Old May 23, 2025 | 06:07 PM
Fly skids up!'s Avatar
Fly skids up!
This is 100% correct. If I may add to Eric's post this is a common failure and I believe the root cause of this failure is the excessively wide (.045") spark plug gap. 0.035" is what I consider the maximum Gap should be.
Old May 24, 2025 | 11:16 AM
yes i did, no spark
Old May 24, 2025 | 11:17 AM
would this be something that causes to car to spontaneously stop working
Old May 24, 2025 | 11:25 AM
ive looked through the manual and there isnt anything for this specific issue, is there a certain section you might know that i might have missed?
Old May 24, 2025 | 11:27 AM
i went to autozone and picked up a new ignition coil, then cleaned the distributor contacts with electronic cleaner and a dremel. The car started with a misfire so i shut it off and traced my plug wires to their correct positions and now it wont start again
Old May 24, 2025 | 11:35 AM
ctmccloskey's Avatar
ctmccloskey
Listen to Tom, he is a resident expert on the subject of Crossfires. Follow the advice and get the GM Factory Service Manual (only) and start troubleshooting as the FSM's have the very best information for this type of issue.
I have seen plenty of Ignition Coils that worked fine one day and died the next. Either parked or being used. Then start on the distributor, coil, wires and plugs. Do what was suggested above and use that FSM to tell which way to go. If you start throwing parts it could/will get very expensive.
Listen to Tom!
RockAuto sells the FSM's and other manuals on DVD for a lot less than the hardcovers. Those are also available but are costly. Personally I could not maintain my 1988 C4 and it's L98 without that FSM, it is 2 big manuals that cover Mechanical and Electrical system with incredible troubleshooting.
Old May 24, 2025 | 06:14 PM
MelWff's Avatar
MelWff
No, HEI is .045 initially when released it was .060 and GM had issues.
Old May 24, 2025 | 09:33 PM
Ahrmike's Avatar
Ahrmike
how did you clean the dist contacts with a dremel? when you changed ign coil, you rewired the coils wrong? really sounding more and more like the ignition control module, which sits under the rotor. if you dont have a spare you might want to buy one and swap to see if it fixes the issues. if it doesnt, keep one as a spare since they are known to go out.
When it started and had a misfire, did it sound like it was missing on a single cylinder or just randomly misfiring? if random misfires, you could check your timing...
To Crossfire issues
