4 speed backup switch wiring
Old Feb 13, 2003 | 02:09 PM
sb69coupe's Avatar
sb69coupe
Default 4 speed backup switch wiring
Can someone tell me where the wiring for the backup light switch plugs in at the firewall? When I pulled my transmission the wiring was long gone. I want to check to make sure the rest of the wiring is in place before I spring the $$$ for a new switch and rods.
Thanks,
Shannon
Old Feb 13, 2003 | 03:07 PM
wombvette's Avatar
wombvette
Default Re: 4 speed backup switch wiring (sb69coupe)
Two wires pink/green and a plug hanging off the LH firewall near the tunnel.
Old Feb 13, 2003 | 03:11 PM
sb69coupe's Avatar
sb69coupe
Default Re: 4 speed backup switch wiring (wombvette)
Thanks Wayne! I'll take a look to make sure Bubba ain't been 'round there. I assume one is +12v and the switch just completes the circuit, causing the backup lights to come on. If I jumper the pink to the green, that should tell me if the rest of the wiring is OK, right?
Oh yeah, thanks for the work so far on the a-arms and tie rod sleeves. They are cleaning up real nicely. Too bad the back of the car still reeks of tranny lube.
Shannon
Old Feb 14, 2003 | 09:36 AM
Surfer69's Avatar
Surfer69
The wires before the plug come from up near the firewall close to the steering column.
To 4 speed backup switch wiring
