1982 cross fire problems
anyone have a recommendation in the southeast would help.
thx in advance for your help
Only a #'s matching maniac has Any interest in a #'s matching mechanical set up for performance. So it is solely a factory example.
By the way if your's has a hatch then it is a Collector Edition as they were the only C3's with a hatch. Or is your's a C4
If you are up for it, let us know. buc has been a huge help and ive learned a lot from the forums. theres maybe a half dozen sensors that affect how the ECU runs the engine. other than that, its the same thing as a carb'd car with the slight added complications of the ECU potentially failing.
There are a couple of things that these motors are rather sensitive to, fuel pressure and balance which gives these cars a bad name. Get those two right and you are on your way to a nice running motor. Yes, we can talk about all the other things that come into play like the IACs, TPS, CTS etc... But those are no different than any other car sensor on newer models and when they go bad, you replace them. The really bad thing about these cars and the ANY other CFI car is the ECM. The ECMs are 43 years old right now on the 82. Electronics don't last forever and the the ECMs are almost extinct, when they go bad, you could be in trouble. Without a good ECM, the car is a paper weight. There are/were ECMs available that took care of that issue not long ago, but they have dried up since Sept of last year. I'm taking a trip to PA in a couple weeks in hopes of taking care of that issue and we shall see if I can make ECMs once again available for CFI and everybody will be happy again.
Other than that, I would highly suggest you purchase the GM 82 corvette service manual and read it. If you don't want to do that, get your wallet out and find some shop that is willing to work on it and MAY NOT have a clue what to do with the car and charge you a fortune. Lastly, if all else fails, you can sell the car. Sounds harsh, but it is reality. Most people here that know CFI only try to help others that are in need. I wish you good luck with your 82 or quest for a good shop.
The truth is the OP doesn't want to get dirt under his fingers nails and wants someone else to do the heavy lifting. I looked at some of the OP's other threads and it's mostly made up of buying and selling of cars. So make of it what you think. And remember, you can bring the horse to the water, you know the rest.
Price allowing, put me on the list of an available backup ECM. Honestly, Im not trying to make this car fast since I have an LY6/Boosted GS in the works. i love how EASY it is to start, how well it generally runs, and how little I have to mess with carb tuning. I want to keep this car on the TBI as long as I can.
Buc, I was referring to you looking into making the ECMs available - are you planning on just picking up a bunch or spares, or are you looking at getting replacements built?
If there's enough interest, I suppose we could probably get a standalone ECU + a premade harness and some basic tune + self tuning system to run the TBIs...
