Trailing Arm question
Old Jun 3, 2025 | 10:05 AM
malicatasr's Avatar
malicatasr
Default Trailing Arm question
My trailing arm bearing on the passenger side wiggles a little bit if I grab the wheel at 12 and 6 and lift a little bit. I just had the trailing arm out and did the bushing and the bearing seamed fine, it's whisper quiet. Anybody have any advise. Thanks in advance
Old Jun 3, 2025 | 02:36 PM
GTR1999's Avatar
GTR1999
I don't see a lot of movement in the 1/2 shaft, but maybe a closer look will help. At 12 & 6 the movement usually showed inner axle wear or poor posi set up. At 3 & 9 you should not have any play and would be loading the outer axle bearings.
Old Jun 3, 2025 | 03:33 PM
malicatasr's Avatar
malicatasr
GTR1999 It was a pleasure speaking with you today. Thank you for your insight.
Old Jun 3, 2025 | 07:12 PM
GTR1999's Avatar
GTR1999
You're very welcome
To Trailing Arm question
