Leaking TKO-600
Old Jun 3, 2025 | 11:06 AM
drwet's Avatar
drwet
Default Leaking TKO-600
I have had a TKO-600 in my '79 for about ten years now. From the day it was installed it has leaked oil. I keep a pan under it in the garage, add oil every year, and keep telling myself I should do something about it. Last summer I put some dye in the oil and determined that it is leaking virtually everywhere. So I figured, great, I'll have to pull it out and have all the seals and gaskets replaced. Since then I have discovered that the more I drive it, the more it leaks. Now I'm starting to think it might not be vented properly. Has anyone ever run into this problem, does it make sense, and what are the chances I can check and/or replace the vent with the trans in the car?
Old Jun 3, 2025 | 08:05 PM
OMF's Avatar
OMF
The only issue I had with my TKO was with the output yolk leaking because the plug wasn't sealed with sealant.....otherwise dry as a bone.
Old Jun 3, 2025 | 08:30 PM
socal_tom's Avatar
socal_tom
I had a TKO 600 never leaked a drop, Goggle it and you will find the answer
Old Jun 3, 2025 | 10:33 PM
drwet's Avatar
drwet
Since I posted that, I contacted the supplier of my transmission. Apparently it is not an uncommon problem with early TKO-600s. They tell me the early ones were assembled with an anaerobic sealant which leaked. Later transmissions used silicone which did not. I was hoping for a vent problem, but it looks like a complete disassembly and reseal is the treatment of choice. Always nice to find the solution. Not so nice to find it is going to be expensive.
Old Jun 3, 2025 | 11:26 PM
69L88's Avatar
69L88
Curious as to who you contacted. I have one that is still in the box and is about 15 years old but may be installing next year.
Old Jun 4, 2025 | 12:19 AM
socal_tom's Avatar
socal_tom
Glad you found the correct answer, it's to bad the work it will take to make it right
Old Jun 4, 2025 | 09:46 AM
drwet's Avatar
drwet
Sent you a PM
Old Jun 5, 2025 | 07:19 AM
stingr69's Avatar
stingr69
My output yoke leaked from day 1. Warranty was to return the yoke to them and they tack welded a sheet metal plug over the end of the yoke. Sealed it with JB Weld epoxy smeared over that. Not pretty but it does leak a lot less. Seems like I could braze the plug for a better seal as it still does it. Some day.....
JB Weld was just slathered on over the cap.  You can see the fingerprints.  Not pretty.
Old Jun 7, 2025 | 11:54 PM
jyounane's Avatar
jyounane
My TKO 600 leaked from the breather. My transmission shop modified it but I cannot tell you the nature of the changes. See below.
Joe
To Leaking TKO-600
