Rear caliper line C3
Old Jun 6, 2025 | 06:51 PM
signify's Avatar
signify
Default Rear caliper line C3
Which bleeder do you use on the rear calipers top or bottom bleeder point
Old Jun 6, 2025 | 07:03 PM
HeadsU.P.'s Avatar
HeadsU.P.
I have no bottom bleeder. Right from the manufacture or rebuilder, the bottom port should have a permanent plug.
One port gets the brake line, one port gets a plug.
But anyway, bubbles rise, use top bleeders (2)
Old Jun 6, 2025 | 07:13 PM
kansas123's Avatar
kansas123
When you bleed the rear brakes, you bleed both the inner (first) and the outer bleeder screw.
Old Jun 7, 2025 | 09:11 AM
signify's Avatar
signify
I assume this is the front of the caliper facing the door.?
Old Jun 7, 2025 | 11:33 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Yes - the bleeders are at the top of the housing for the rising air bubbles to escape.
To Rear caliper line C3
