68 brake light switch
Old Jun 9, 2025 | 09:21 PM
greggome's Avatar
greggome
Default 68 brake light switch
I need to replace my brake light switch on my 68. My manual doesn't show how to replace it. Has anyone attempted this? not sure how to get at it without taking the dash apart.
Old Jun 9, 2025 | 10:10 PM
thomas68's Avatar
thomas68
Take the drivers seat out and lay on your back, it seems impossible, but it isn't. I did it on mine. There should be several threads on it if you do a search. I didn't remove the seat, but wish I had.
Old Jun 10, 2025 | 07:49 AM
WESCH's Avatar
WESCH
Hi
I only read bad things about the available replacement switches, that's why I installed a ordinary switch . I also couldn't work out how to get to this switch. It is hardly visible.
It is rather easy to install a 69 switch.
Brgds
Old Jun 10, 2025 | 03:18 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Pulling the seat is the best idea.....take a picture before you remove it to get it back in correctly....being upside down in a cramped area will mess with your mind when yo go to put it back in
Old Jun 10, 2025 | 04:17 PM
greggome's Avatar
greggome
how did you install the 69 switch? I might give that a try.
Old Jun 10, 2025 | 06:41 PM
Rescue Rogers
It wont work without modifying the pedal
Old Jun 11, 2025 | 08:03 AM
Eliredandblack's Avatar
Eliredandblack
Use a bench located outside the car to rest your legs on. Working in those tight quarters is no picnic, the more you read and look at how others tackled the job will be extremely helpful. The seat removal is a no brainer. Are you 1000 % positive that the switch is bad? ? ? I changed out the hood cold air intake door switch ( located behind the accelerator pedal), you guessed right, it wasn’t the switch! The problems was caused by the accelerator pedal not hitting the switch arm. The fix was to add a piece of rubber so the accelerator would hit the switch. Live and learn.
To 68 brake light switch
