Noise after top end install
Old Jun 16, 2025 | 10:49 AM
KT35's Avatar
KT35
Default Noise after top end install
I installed the E-Street EFI 338 HP Top End Kit in a 1977 corvette. New chain, lifters, cam, intake, pushrods, heads, and carb.
After install I started car and ran for 30 seconds and shut off and fixed an exhaust leak. started car again and the car ran great. Started to bring throttle up to break in cam. The car started making a weird. noise. I have not clue what it is. See the attached video link.
I have since taken car back apart. All lifters look great, nothing rubbing on valve covers, nothing rubbing on timing cover, timing chain looks great no rubbing.
Any help would be appreciated.
File Type: mov
Old Jun 16, 2025 | 01:17 PM
Piersonpie's Avatar
Piersonpie
Not sure if it’s related, but for breaking in a flat tappet cam you usually want to get the RPMs up right away.
Old Jun 16, 2025 | 02:10 PM
sunflower 1972's Avatar
sunflower 1972
I suspect that sound is coming from one of belt driven accessories ie, power steering, alternator, AC compressor, water pump. I think I'd put it back together and run it without the belts for those accessories and put them on one at a time to find the noise.
Old Jun 16, 2025 | 02:37 PM
Rebelyell's Avatar
Rebelyell
Break-in raise revs right away: as in Immediately & Coincidentally with startup.
Check those belts and pulleys; also water pump itself for that ugly noise. If you take belts off and noise stops as a result; that all but guarantees noise ain't from within motor.
Check for wobbling-failing fan clutch which may let fan tip scrape against shroud. Drizzle a little water on belts will briefly quiet them if they are offending.
Seems you have Two belts? Remove one at-a-time which, by elimination, May (may not) focus your sonar to home-in on culprit(s).
Also, remove valve covers and check each & all 16 pushrods and verify they are rotating while at idle. if PRs are rotating that's a good sign that verifies Lifters are rotating as well. Yes, it's messy.
Also, verify flywheel/pressure plate/flexplate/converter bolts are torqued to spec; if flexplate, verify it's Not cracked.
*Flat Tappet Lifters Must Rotate or else Both Lifter & Lobe Quickly Fails: terminally.
** is that noise coming from distributor? if cap ain't seated both squarely & tightly, it'll run but rotor can hit inside cap making noise.
Old Jun 18, 2025 | 09:02 AM
KT35's Avatar
KT35
I started the car and brought the RPM up right away.
I left all the belts off the accessories and still have the same noise
Verified the distributor cap is in place and tight.
I didn't touch the flex plate but I will pull the cover off and verify the bolts are tight.
I'm at a loss to be honest.
Old Jun 18, 2025 | 11:31 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
I don't think this is an engine noise because it's irregular, so I'd forget about it temporarily and make sure you break in the cam before anything else. After that, a stethoscope (very inexpensive at Harbor F. works extremely well) poked around on various parts and engine locations will lead to the source. It's actually kinda cool to hear ball bearings and engine workings.
I'd bet it's coming from your water pump pulley and fan setup. You can remove these parts completely and run the engine without them for a couple minutes without risking any damage.
Old Jun 18, 2025 | 11:54 AM
KT35's Avatar
KT35
I ran the car with out the water pump and fan on the car still made the noise.
Old Jun 18, 2025 | 12:04 PM
barkingrats
Originally Posted by KT35
...still made the noise.
Time for a stethoscope.
Old Jun 18, 2025 | 12:14 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
I hope you didn't really try and break-in a cam like that. Once you start a motor with a FT cam for break-in, you take it up immediately to 2k and hold it there and then vary it a small amount (couple hundred rpm up and down and NEVER idle) for at least 20/30minutes and an exhaust leak is no reason to stop the process IMO. I have done plenty of FT cam break-ins with open headers. Starting and then shutting off and starting again and waiting to go up in rpm is not good on a new break-in. However, that sound does not sound like a cam related issue, but more like a bad belt. If you removed all the belts and started it with the same sound, obviously there is an issue inside the motor somewhere in your installation process... (timing chain maybe?) I personally do not believe in wasting money on a FT cam anymore and always go roller or retro roller kit no matter what. To me, it's just not worth the possible aggravation today to not go roller, I will spend a few dollars more for piece of mind and better performance. Can something go wrong with a roller, yes, but the chances are MUCH less. Everyone has their own opinion on this topic, but that's just me. GL and post up what you find.
Old Jun 18, 2025 | 12:58 PM
Rebelyell's Avatar
Rebelyell
Did you remove pump itself from engine? Yes ? And engine continues to make same noise ? Yes ?
Did you remove ALL belts from engine ? Yes ? And engine continues to make same noise ? Yes ?
Have you applied a hi-pressure grease/paste to BOTH distributor's bottom gear AND Cam's dist drive gear ? Yes ?
Did you inspect distributor And confirm rotor is firmly attached AND cap is properly seated & secured ? Yes ?
Are Both Cap & Rotor name-brand pieces ? Yes ? Are they Both of same brand ? Yes ?
*add*
Did you confirm the Fuel Pump is firmly & squarely attached to passenger side of block and its bolts are torqued to spec ? Yes ?
Did you install a "different" or "new" oil Dipstick OR dipstick Tube ? Yes ?
Old Jun 19, 2025 | 05:56 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I think Mr. Buccaneer would be mortified if he saw how I break in a new flat tappet cam.
Imagine back in the day, every GM , Ford and Chrysler product engine was running flat tappet cams. I have no idea how many years factory engine's were made this way. A lot.
And ALL those brand new flat tappet engine's. We just started them and drove away. Absolutely nothing else.
When I put a new flat tappet cam in my 350 8 years ago. I just started it up. Set the timing, adjusted the idle speed mixture screws. Yes, with it idling. And then took it for a drive. Never gave it a second thought. We never did when they were brand new. Why now?
Old Jun 19, 2025 | 06:33 AM
randallsteel's Avatar
randallsteel
When I first heard the video my thought was a pulley/belt squeak. But you said it makes the same noise with all accessories idle.
the fact that it’s squeaky makes me think it’s a rubbing issue.
are any of the pushrods in a bind against a guide plate? Is the front of the cam/timing gear rubbing the timing cover?
Can you tell if it’s louder at the front of the engine or the rear?
Old Jun 19, 2025 | 09:41 AM
barkingrats
Why now?
In replying to a thread on how the CE warranty engines were stamped it struck me how many replacement short blocks Chevrolet was making every year. Flint and Tonawanda each had their own range of numbers to identify 30,000 replacement short blocks per year. When that range was used, they rolled the numbers over and began using a letter before the sequential CE number. Keep in mind this was a short block and not just a replacement cylinder block which seems to have had a separate number system.
I've not looked deeply into the CE program, but I think I've seen CEx Cxxxxx stamps, meaning for that single year they produced over 60,000 warranty replacement engines from a single engine plant. That seems like a pretty substantial number of engine failures in a warranty period.
Old Jun 19, 2025 | 12:44 PM
Buccaneer's Avatar
Buccaneer
Yikes! OK, it's cool and I get it really and value your opinion, as always. Back in the day, you could more than likely get away with doing that, I never did that, even back then though. Remember getting Sunoco 260 at the pump as well for cents on the dollar? Today, that's a completely different story IMO because of various reasons, material used from various country's, quality control (or lack of it) oil quality, zinc etc... That is also why today I never go FT, only roller regardless of the cost. 25 plus years ago, which would have been my last FT cam install and I even used a bottle of GM EOS during break-in just to have that extra warm fuzzy that maybe my cam would not go flat, it never did nor on any motor I ever built, but it only takes one right? Also, how far you are going back? ALL my back in the day motors were solid lifter cams starting with the 69 Z28. The only reason I even mentioned my post is because I cringe when I see a member here tell the horror story of a new build with a FT cam that went south at break-in regardless of technique used and have to spend a boat load more money again and a ton of a&& pain to fix it. Everybody has their own way of doing things and if it works, it works, I guess.
Old Jun 20, 2025 | 07:19 AM
stingr69's Avatar
stingr69
Might be the sound of a fuel pump pushrod scraping against the long bolt used to hold it in place for assembly? Left it in by accident?
Old Jun 20, 2025 | 07:36 AM
4-vettes's Avatar
4-vettes
How far back do I go? Early 60's. I wasn't really a professional mechanic until the early 70's. My most recent build? Yes I used plenty of assembly lube. Yes I add the required extra zinc. And a half bottle with each oil change after break in for two changes.
But that's is actually more than required, and all that I do.
In the mid 70's. The car was started on the assembly line, driven out to a storage yard. No revving break in. Then started. Driven onto transport. Then driven into the dealership yard. Sat for several months
someone finally purchased it. Drove out of the dealership with the rear tires screaming! And, yes, there were a few issues. But I was there. There were actually damn few issues!
I have never done anything above making certain that proper assembly lube and brake in oil is being used. I have never run the engine up to 2K RPM and held it there for 20 minutes. Never.
I have never had a problem.
Old Jun 20, 2025 | 08:13 AM
augiedoggy's Avatar
augiedoggy
If you can find NOS flat tappet cams and lifters they work well... todays hobby market replacements? hit or miss especially the lifters and this topic has been beat to death but some have found good working combinations and some have just seen too many failures.
I had good luck breaking mine in but decided after 8 years to go to a retro roller anyway for other improvements and to be able to run modern oil formulas without the additives. Then again it cost me about $600 to convert from a flat tappet to a comp retro roller cam and many here claim it costs thousands so YMMV.. My engine was already upgraded from the stock stamped rocker arms and had performance heads. the roller just made sense for its improved power from the area under the curve which widened the power band by keeping the valves open longer for more filling and exhaust on each stroke making it a better pump.
To Noise after top end install
Old Jun 20, 2025 | 08:37 AM
4-vettes's Avatar
4-vettes
Absolutely Augie. Now imagine you are on the other side of the planet. And you're 600 dollars becomes 1,800 dollars just like that! And you question, is it really 1,800 dollars more power? And even if it is, do I wish to wait another year to save that much more money? Or drive now?
Old Jun 20, 2025 | 08:41 AM
augiedoggy's Avatar
augiedoggy
Fair enough.. In fact I went FT the first time because of the budget and options available to me at the time.
Old Jun 23, 2025 | 10:17 AM
KT35's Avatar
KT35
I looked all over the car including fuel pump and flex plate and torque converter. Nothing. I knew I couldn't start and idle the car anymore. I made the call to start the car and break the cam and lifters in. It was either going to break in or break!
I started and ran the car at 2000-2500 for 30 min per the instructions. The sound in the video lasted for about 20 seconds and then it was gone. Motor ran great during the break in. After the break in I brought the car back to idle, it ran perfect no noise.
Shut the car off and then notice a radiator fin leaking. F$%K this car is fighting me.
