electrical Issues
Old Jun 16, 2025 | 04:10 PM
C3FIXER's Avatar
C3FIXER
Default electrical Issues
1977 L82 4 speed. I have had my vette down for about 18 months doing major repairs/replacement parts so the battery has been disconected during this time. The right side and middle 2 pc. console was removed and all of the original heating and a/C taken out. I will replace with Vintage air later down the road. I installed the upper Console and re-connected the battery but the Rear Compartment Courtesy light will not shut down also when I swirch on the key to power up the instruments my Tach goes up to about 2000 rpms. I did add a new tach filter so maybe I soldered the wrong line. I have the hot side pink wire installed to the distributor closest to the firewall and the tach wire in front. I have not started the newly rebuilt engine because I need to re-set the harmonic balancer at the 16 degree mark. Maybe the Printed circuit has a weak area or some damage, just not sure. I am anxious to get this car on the road.
