ATF change TH400
Old Jun 23, 2025 | 02:31 PM
ZIOGEO's Avatar
ZIOGEO
Default ATF change TH400
Im still sorting out brakes but in the meantime, while waiting on parts, I am going to change the ATF. The fluid is at least 20 years old. Im not finding Dex2 or 3 at any parts store so Im asking what you guys are using and how its working out so far.
Old Jun 23, 2025 | 04:33 PM
DonnieP73's Avatar
DonnieP73
Deleted
Old Jun 23, 2025 | 11:30 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
I used ACDelco 10-9395 Dexron VI in my '72 TH400 three years ago after a stock rebuild. There have been no issues at all with slipping, shifting, etc.
Old Jun 24, 2025 | 07:53 AM
randallsteel's Avatar
randallsteel
Ac delco Dex VI in my th400. No issues
Old Jun 24, 2025 | 06:18 PM
Rebelyell's Avatar
Rebelyell
Not to worry. Rather well-documented; Recent versions of DEXRON are backwards-compatible.
Old Jun 25, 2025 | 11:10 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Old school method is to use Type F to firm up shifts even more. Type F is considered a "high impact' fluid and Dexron is a "high lubricity" fluid designed to smooth the shifts. Both work fine but have different feels on shifts. Race guys use some tractor fluid also.
The T-400 is a tank of a tough trans.
JIM
Old Jun 27, 2025 | 07:59 AM
jb78L-82's Avatar
jb78L-82
JIM
Agree 100% ^^^^^
A built 350 trans is not as good as a stock Turbo 400 a transmission expert told me years ago!
I used Ford Type F in my Nova SS turbo 350 from 1978 to 1990 when I sold that car and literally beat the heck out of it with zero issues at 170,000 miles on the OEM tranny. I ran 2 stand alone coolers (no radiator cooling) in the grille and changed the fluid and filter OFTEN with zero issues.
As mentioned Dexron VI is backward compatible.
You can use either Ford Type F or Dexron VI since the fluid is not nearly as important as changing the filter and fluid often and keeping the fluid cool (run a double stack cooler) with no radiator cooling.
I have used universal synthetic global trans fluids in several cars over the years, currently and in the past, including Mobil1 synthetic ATF, Sunoco Global Trans Fluid (only commercially available), and Valvoline Maxlife (walmart) in various cars including Lexus, Audi, and Ford Mustang GT. ZERO issues in any car!
Old Jun 27, 2025 | 08:59 AM
Eric P's Avatar
Eric P
Dex-Merc sold most everywhere is the old Dexron , Type F if you want to firm up the shifts some
Old Jun 27, 2025 | 09:18 AM
GTR1999's Avatar
GTR1999
JIM
When I built my 72's TH400 17 years ago I used the Ford F.
Old Jun 27, 2025 | 09:22 AM
Motorvation's Avatar
Motorvation
Add one of these. Excellent for valve body operation. Best additive since whale oil…
Steve O.
Old Jun 27, 2025 | 10:56 AM
SEVNT6's Avatar
SEVNT6
When mine came out of warranty in the summer of '77 the 1st thing I did was install a B&M shift kit with Trick Shift fluid.
78k later I'm still barking 2nd gear...
To ATF change TH400
