TH400 line
Old Jun 30, 2025 | 02:39 PM
kansas123's Avatar
kansas123
Default TH400 line
How do you keep the fitting plugged in to the governor (?) On the side of TH400 on '72. Keeps creeping out. Thanks
Old Jun 30, 2025 | 02:52 PM
walleyfisher's Avatar
walleyfisher
You need to reshape the metal line, it should line up straight across from the modulator. The first bend on the line that horizontal to the floor (next to the distributor) needs some of the bend taken out so the line goes up at the transmission end
Old Jun 30, 2025 | 05:22 PM
HeadsU.P.'s Avatar
HeadsU.P.
As Walley pointed out, that's the Modulator which controls shift events.
(I believe the governor is on the other side)
Anyway, some cheap spring-type vacuum hose clamps should work.
Old Jun 30, 2025 | 07:04 PM
Smilie 388's Avatar
Smilie 388
just bend the line until it mates up with the modulator . the factory steel line will actually go inside the modulator and only has a short piece of hose over the junction
Old Jun 30, 2025 | 10:35 PM
kansas123's Avatar
kansas123
Done, thanks
To TH400 line
