1977 master cylinder replacement
Old Jul 8, 2025 | 07:56 AM
signify's Avatar
signify
Default 1977 master cylinder replacement
My replacement ac Delco gold does not have the rubber gasket as the original has. does the old O-ring gasket have to be used for mine is torn ? I can not find a replacement part number as per assembly. . instruction manual. Part number 730392 gasket
Old Jul 8, 2025 | 11:23 AM
kanvasman's Avatar
kanvasman
So you bought a new master cylinder and it doesn't have a lid or gasket for under the lid?
Old Jul 8, 2025 | 12:18 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
I don't have one on my P/B car and don't have any issues. There isn't a need for it to seal vacuum, so I'm not sure its purpose other than to trap leaking brake fluid so it rusts out the brake booster. You could use a large o-ring of the proper OD/ID dimensions to fit the groove, which should be pretty readily available at a decent hardware store in the plumbing section.
#2 is the gasket you asked about, #3, I believe is just a foam ring.
Old Jul 8, 2025 | 12:30 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
This
Old Jul 8, 2025 | 12:36 PM
KapsSA's Avatar
KapsSA
Like said, don't really need it.
If you insist, lay down a circle on a piece of glass with a tube of silicone and let it dry.
Razer blade it up, should work.
Old Jul 8, 2025 | 12:59 PM
signify's Avatar
signify
Thanks for all your suggestions,CSSB said i was second person to acquire about seal.and the need was to catch fluid which could contaiment boosters seal may be.
Old Jul 8, 2025 | 03:39 PM
BKarol's Avatar
BKarol
Davies Corvette shows a replacement for $3.95
https://corvetteparts.com/item/brake...akes-1968-1982
To 1977 master cylinder replacement
