12Volt supply to ballasted coil ?
Old Feb 15, 2003 | 11:42 AM
ukvette72's Avatar
ukvette72
Default 12Volt supply to ballasted coil ?
I have an MSD Blaster 2 coil wired through a ballast resistor. Can i also wire this to one of the terminals on the starter solonoid to get a 12v boost whilst cranking. If so which terminal on the solonoid do i wire it to. Has anyone else done this with a blaster coil ?
David
Old Feb 15, 2003 | 11:31 PM
wombvette's Avatar
wombvette
Default Re: 12Volt supply to ballasted coil ? (ukvette72)
There are three terminals on the starter. The large one for the battery cable and two small ones. The nearest one to the block will have a purple wire and operates the solinoid. The outer one is the ignition that puts a full 12V to the coil.
Old Feb 15, 2003 | 11:36 PM
wombvette's Avatar
wombvette
I just noticed you are from Derbyshire. Say hello to the people at Wombwell Hall. Thats where my name came from.
Old Feb 15, 2003 | 11:54 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: 12Volt supply to ballasted coil ? (wombvette)
:yesnod: :yesnod:
To 12Volt supply to ballasted coil ?
