Top Flight air dam doesn’t fit
Old Aug 2, 2025 | 03:17 PM
JakeLucas's Avatar
JakeLucas
Default Top Flight air dam doesn’t fit
Reference thread:
https://www.corvetteforum.com/forums...thread-10.html
I bought an OEM style air dam from Top Flight. I tried to install it and it didn’t fit. Not like a minor fitment issue, it wasn’t even close. I had my mechanic check it and he confirmed that it didn’t fit. It’s labeled on the package to fit ‘73-‘79. Looks the the correct one. Any suggestions?
The engine runs at around 200-225 degrees on a warm day. It got a little hot after pushing it hard for multiple runs. It also really heats up if it idles for long periods. We’re going to check the thermostat too.
https://www.topflightautomotive.com/...hoCRvcQAvD_BwE
Old Aug 2, 2025 | 04:39 PM
MelWff's Avatar
MelWff
Did you contact the vendor?
Old Aug 2, 2025 | 04:51 PM
pltmgr's Avatar
pltmgr
It seems that a high percentage of aftermarket parts don't fit or are defective. Runs almost 50% for me. I don't think Top Flight is going to come up with solution other than return and refund.
I put an air dams on a 68 and 71 and neither fit without modifications.
Old Aug 2, 2025 | 04:52 PM
Bikespace's Avatar
Bikespace
I'd contact ACI and see if they have that part.
https://acivette.com/
Old Aug 3, 2025 | 05:51 PM
JakeLucas's Avatar
JakeLucas
Yes. They replied:
“We can certainly get that returned for you. I can also take a look and see what we have. What is the exact make and model of your Corvette?”
Make? I get model-but make is funny.
Old Aug 3, 2025 | 06:21 PM
JakeLucas's Avatar
JakeLucas
I’m sure you’re right, regarding Top Fight. It wasn’t like some moderate modifications would do the trick. It wasn't even close.
Old Aug 3, 2025 | 09:44 PM
JakeLucas's Avatar
JakeLucas
Thanks! I emailed them.
Old Aug 3, 2025 | 10:00 PM
interpon's Avatar
interpon
I took a look at that spoiler in the link you had three people gave perfect reviews that it fit perfect. I’m pretty sure that that’s not the whole spoiler that you have to have the extension that rivets to that. I could be wrong. Here’s an OEM installation comparing the two.
https://www.corvetteforum.com/forums...on-advice.html
got any pics of how it doesn’t lineup?
Old Aug 3, 2025 | 10:39 PM
alt66's Avatar
alt66
On a humorous note although getting bad parts is never funny.Repro parts make me think of when I was a kid and the breakfast cereal boxes always had a picture of a great toy you could send away for.When it arrived it never lived up to the expectations I had of the picture on the box.
Old Aug 4, 2025 | 08:27 PM
SteveG75's Avatar
SteveG75
The extensions were only used on certain L-82 cars with AC.
Old Aug 4, 2025 | 10:29 PM
sphil's Avatar
sphil
Its like those big thick juicy burgers restaurants advertise on TV, then you go buy one and it’s half the size.
Old Aug 4, 2025 | 11:03 PM
Bikespace's Avatar
Bikespace
Perhaps this is the correct part at Zip? The Top Flight part number shows that it was a former Corvette Mods part.
https://www.zip-corvette.com/73-79-s...t-spoiler.html
@interpon is one of those the center piece of the 78 Pace Car front spoiler? It looks like the two sides bolt onto it (there's a photo at the Zip link, below, which is likely an ACI part).
https://www.zip-corvette.com/73-79-p...pc-design.html
Old Aug 9, 2025 | 01:55 AM
Rebelyell's Avatar
Rebelyell
Just maybe, perhaps TF sent the right box with the right label, But inside the box was an air dam for a different year; right box but wrong part ?
Old Aug 14, 2025 | 11:38 PM
JakeLucas's Avatar
JakeLucas
The first one is what we want. Not the second style.
Old Aug 15, 2025 | 06:29 AM
CraigH's Avatar
CraigH
I found with my 71 that the aftermarket ones all had gaps when fitted.
Cant say that my front apron was perfect as it had been repaired a few times so not sure how much was the apron vs spoiler.
In the end I found it easier to reshape the fiberglass to fit as I was repairing it anyway.
https://www.corvetteforum.com/forums...ourney-48.html
Old Aug 18, 2025 | 09:33 AM
JakeLucas's Avatar
JakeLucas
I think that it’s probably the right part but the front apron might have been modified.
Not sure how to move forward. Many have said how essential it is to have an air dam for proper cooling. So far it’s been doing well. It does heat up with prolonged idling though. We’ll have to check the thermostat and either figure out a way to either make it fit or fabricate one.
To Top Flight air dam doesn’t fit
