Engine sitting to low
Old Sep 2, 2025 | 08:47 AM
HeadsU.P.'s Avatar
HeadsU.P.
Flyncold,
Pretty rare for oil pan to hit header & vice versa.
Worse case scenario. Somebody makes / sells a header flange spacer.
Might move the header over just enough to clear the pan.
Problem is with a spacer is, you now have to incorporate two gaskets.
Which means twice the odds of a header leak.
Old Sep 2, 2025 | 08:51 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I used those on a 327 once with raised exhaust ports to clear an issue...dont remember what it was. But you should post pics of the issue before we start making suggestions... I personally would like to see the pan and the header and why it is hitting... that just doesnt make any sense as to a header wrapping that far under the engine unless its not for a corvette...
Old Sep 2, 2025 | 12:35 PM
OldCarBum's Avatar
OldCarBum
This could also be because the oil pan has wide kick outs for larger than standard oil capacity.
Some header manufacturers will list the dimensions for oil pan kick out on their websites.
This is just one more aftermarket component that fitment is based on installing their header on an all factory original vehicle without modifications like aftermarket oil pans, steering systems, suspension systems, starters, air conditioning etc…
Old Sep 3, 2025 | 04:43 PM
SteveG75's Avatar
SteveG75
Which is why I like my Milodon with stepped sump. Helps keep the pickup covered.
Old Sep 3, 2025 | 05:14 PM
7t9l82's Avatar
7t9l82
I have the Milodon pan also those angled kickouts help horsepower to a degree by keeping oil from getting to the crank throw. Plus I like the extra capacity.
Old Sep 3, 2025 | 06:32 PM
OldCarBum's Avatar
OldCarBum
Originally Posted by Flyncold
Hello OldCarBum,
i ended up going with the Moroso 21811 pan and got he clearance i needed but wouldn't you know it, now the header hits the side of the oil pan and won't bolt up. It's all my luck. I'm running Headman Headers for my 80 model and during the first fit with original oil pan didn't have any issues. What headers are you running?
I’m running Hedman 68090 long tube with 2” primary tubes and 3” collector.
I purchased them uncoated and after fitment, I had them ceramic coated.
I’m also running a Moroso 20403 oil pan.
I have no clearance issues and plenty of room between the headers and the oil pan.
But my part numbers will be different because I’m running a 496 big block and you are running a 383 small block.
Old Sep 4, 2025 | 02:11 PM
Rebelyell's Avatar
Rebelyell
Does the subject 383's heads have "raised exhaust ports" ??? Yes or No ?
Is the aftermarket pan configured for heads with "raised exhaust ports" ??? Yes or No ?
Moroso 21811 IS a wet sump true Road Race Pan.
MOST wet sump true Road Race Pans, by their very nature, have wide kickouts at sump; both R&L, And Sumps are Much wider than OE pans' sumps.
This M 21811's SUMP most definitely has a Much wider footprint than OE pans.
No free lunch.
Old Sep 4, 2025 | 02:41 PM
OldCarBum's Avatar
OldCarBum
No free lunch.
Very true.
It takes a lot of time and research to build an engine for a specific year model vehicle to make everything work and fit together.
Old Sep 4, 2025 | 02:56 PM
7t9l82's Avatar
7t9l82
Milodon 30900 Milodon Street and Strip Oil Pans | Summit Racing https://share.google/MYWbcMdAOOrlZSQVy
Old Sep 5, 2025 | 09:14 PM
Rebelyell's Avatar
Rebelyell
No doubt that's a good pan for you, but that's a street-strip (as in drag strip) pan & also known as a T-sump pan; it's not a Road Race pan. And it hangs down even lower and closer to pavement than an OE pan. For low-slung chassis that're driven hard left & right I recommend a true Road Race pan; most are more shallow than OE but, nevertheless, have greater capacity. Most RR pans have a Broad footprint; Much wider and longer sump than OE. FWIW, Most real CT and RR pans' footprint is large enough that motor will sit stable on pickup bed or shop floor. Supported only by pan & gravity.
Old Sep 5, 2025 | 11:32 PM
OldCarBum's Avatar
OldCarBum
Have you read through the entire thread?
The OP was having fitment issues between his steering components and his oil pan, so several people suggested certain oil pans that would remedy his issues.
Next the OP stated his Hedman headers were hitting his oil pan so the current topic was to help him remedy his header clearance issue.
Buying a deeper pan with wider and longed kick outs like any road race pan will only make his problems worse rather than giving him the clearance he needs.
What road race pan are you running, on what year Corvette with what engine, with what steering, that works on your year model, without interference with the steering components and headers?
Are you road racing or auto crossing your car?
Can you supply any pictures?
Old Sep 5, 2025 | 11:36 PM
7t9l82's Avatar
7t9l82
Actually my car in front is lower than stock and does not extend below the cross member so I don't see the problem . But you have to pick the pan for your purpose. But I will say Milodon is hard to beat.
Old Sep 6, 2025 | 01:03 AM
  #33
Rebelyell's Avatar
Rebelyell
Road Race pans are typically much shallower and hang down even Less than an OE pan, and Much less than the aforementioned street-strip pan.
It doesn't matter which street-strip pan you have or what I have or have worked with. Although I'm not there in person to see his pan, car or headers; I'm attempting to assist Flyncold with his fitment. And, no, I didn't suggest or infer he buy another pan in addition to his M 21811 Road Race pan; that ship's sailed.
Moreover, not gonna get into a bio quiz/pizzin' match while trying to help someone else.
And so, continued good luck with your project, sir.
Old Sep 6, 2025 | 09:15 AM
  #34
augiedoggy's Avatar
augiedoggy
Originally Posted by Bikespace
If the interference is only from the steering cylinder, could your issue be solved by either converting to manual steering, or to Borgeson steering?
This s what I did... prior to that when I built the last engine for the car like 13years ago I just took the c3 corvette specific oil pan off the l48 and put it on the new 355 I built. With the borgeson I was able to use a regular oil pan on my 406 plus my steering feel is improved. I also swapped in an OD trans but mine bolted in ok. not only is the c3 oil pan shaped to clear the steering system, its also a lower profile shallow (like 6.8") pan. I have lowered my c3 so hopefully I want regret the 7" pan I used myself.
BTW I looked at and almost bought the low profile circle track race pan with the side kicked out as it wouldnt hit anything on my vehicle but I decided not to for other reasons
Old Sep 6, 2025 | 09:27 AM
  #35
augiedoggy's Avatar
augiedoggy
I replaced my steering box with the Borgeson while engine was out but it didn't change the cylinder height. We are just going to change the oil pan out and hopefully that fixes it.
Did you use the borgeson jeep upgrade type box or just a stock reproduction from borgeson? the borgeson jeep box allows the cylinder to be removed altogether as well as all those leaky high pressure lines under the car. there is a kit for the c3 vette from borgeson that has everything to do this but ive read its been backordered for a while now.
Old Sep 7, 2025 | 02:41 PM
  #36
Rebelyell's Avatar
Rebelyell
Circle aka Oval Track wet sump pans Not recommended for street cars. They are purposely designed for repeated High-G, Left-Hand ONLY turns, where oil is thrown primarily against Right side of pan. They're configured for a pickup that's routed into Right side of pan and their sumps have gates/doors/runners configured to assist in Right side pickup & oil-return to Right side. Their sumps are typically kicked out on Right side Only.
