Starting issue
Old Aug 12, 2025 | 08:50 PM
VettePekka's Avatar
VettePekka
Default Starting issue
So, my starter went bad and I replaced it with a mini starter.
1969 w/ manual transmission. Non-original 400 CID, and MSD ingnition.
I hooked everything up and went to start, and nothing, except a “click” sound coming from somewhere behind the dash.
To eliminate the clutch switch as a potential culprit I bypassed it. still nothing but a “click”.
The starter does engage and turn if I connect the starter main terminal & s terminal with a screwdriver.
Where does the wire to the s terminal come from?
Thoughts? All help is appreciated.
Old Aug 12, 2025 | 10:16 PM
Dogmark's Avatar
Dogmark
Sounds like you’re solenoid went bad
Old Aug 13, 2025 | 08:08 AM
HeadsU.P.'s Avatar
HeadsU.P.
Pekka,
Something tells me "one" wire is on the wrong solenoid post.
Anytime a starter is to be removed, take a picture of the wiring AND label all wires with masking tape / Sharpie pen.
You won't remember which wire goes where, minutes later.
Member Peterbuilt has a picture of the correct solenoid wiring and might come along here soon.
Old Aug 13, 2025 | 11:35 AM
Peterbuilt's Avatar
Peterbuilt
Old Aug 13, 2025 | 11:38 AM
bruiser's Avatar
bruiser
St. Jude Donor '15
The solenoid wire comes from the clutch safety switch which gets its power from the ignition switch when starting.
Old Aug 13, 2025 | 02:32 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
post a pic of the solenoid on the mini starter. There are different style solenoids and some require an inline diode to shut off once they start
Old Aug 13, 2025 | 08:55 PM
kansas123's Avatar
kansas123
Originally Posted by HeadsU.P.
Pekka,
Glad I'm not the only one. Hate getting old..............
Old Aug 13, 2025 | 10:03 PM
Peterbuilt's Avatar
Peterbuilt
You are not alone, I'm 79.,
To Starting issue
