Hi all. Need to get longer wheel studs. I installed the spacers below:
Wilwood 0.197 inch Wheel Spacers 300-11961
Due to the new wilwood calipers being a hair too big and scrapping the inside of the wheel. Regardless I need new studs. I believe something like 1/2-20 in. x 2 in. Long, .589 in. Diameter Size? Any thoughts and any suggestions on new lug nuts while I’m at it?
While im at it, any suggestions on new lug nuts.
have you considered looking for longer shank lug nuts to reach the current studs... how far did you space out?
sorry just seen spacer size... you should be fine with longer shank lug nuts, im doing the same right now with 5mm spacers and 1/4" longer shank lug nuts
Those spacers look like the old type used back in the 70's to use Crager SS wheels on a vette. They would cause the lug nuts to loosen over time, sometimes causing a problem.
