body bushing replacement
Old Aug 16, 2025 | 04:52 PM
ptaleo's Avatar
ptaleo
Default body bushing replacement
I have a question. Is it any easier to replace body bushings on a 78 with out removing the body while the engine and trans currently being out?
Old Aug 16, 2025 | 06:01 PM
OldCarBum's Avatar
OldCarBum
Having the engine and transmission out won't make the job any easier.
The trick is getting the body raised enough to swap out the bushings.
If you have big hands, it makes things just a little harder.
Old Aug 16, 2025 | 06:06 PM
alt66's Avatar
alt66
With the engine out that much less you have to disconnect to raise the body.
Old Aug 16, 2025 | 07:34 PM
ptaleo's Avatar
ptaleo
Thanks, good to know.
Old Aug 16, 2025 | 07:35 PM
ptaleo's Avatar
ptaleo
Thanks for the info.
Old Aug 16, 2025 | 09:38 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Maybe the shifter disconnect. That's about it. Can't think of a single thing on the engine that connects to the body.
Some disconnect the brake lines from the master. But that's not engine, and of course the steering column needs disconnecting. And on and on.
But to change body mount bushings your lifting the body.
I did it one side at a time. A lot of us do. But I left my engine and trans in the car.
No, it was not easy.
Old Aug 17, 2025 | 10:44 AM
69L88's Avatar
69L88
The #2 and #3 mount bolts are the most challenging in terms of being able to remove the bolts without destroying the captive nuts.🔩 Repeatedly soak the areas with PbBlaster/equivalent for several days, yes, days, before attempting.
If you have an acetylene torch, you can apply localized heat to the nut but you need to be VERY careful and know what your are doing.
To body bushing replacement
