1979 Corvette Alarm
Old Sep 5, 2025 | 07:26 PM
stosti's Avatar
stosti
Default 1979 Corvette Alarm
Where can I buy a new C3 Alarm Horn? If I cannot how do I completely remove the factory alarm from this car? It blows fuse 16 when it trips! It also goes off occasionally. It needs to go.
Does anyone know if it has an ignition kill feature or does it only blow the horn? Does the horn stop on its own or does it only stop if you unlock the door with the key?
Is there a wire on the driver's door lock that electrically sets the alarm and where does it go?
Thank you!
Scott
Old Sep 5, 2025 | 08:13 PM
bmotojoe's Avatar
bmotojoe
Originally Posted by stosti
How do I completely remove the factory alarm from this car? I set it to test. It also blows fuse 16! It also goes off occasionally. It needs to go.
Thank you!
Scott
Did you download the 1979 Corvette Electrical Troubleshooting Manual provided on one of your previous posts?
It's all in the Manual...
Old Sep 5, 2025 | 09:55 PM
stosti's Avatar
stosti
I don't see anything about the alarm.
I don't see anything in the insert that says which fuse is which. Which fuse is the horn? It is no longer working. Does it even have a fuse?
To 1979 Corvette Alarm
