1971 Radiator replacement + shifting issue (automatic)
I am a novice in the garage I would say, so please take it easy on me if I say something stupid! But I can follow direction & am learning from my stepdad (75yr old) and my uncle (81yr). Uncle has built 60 and 61 Corvettes .
Here is what I know about my Corvette.
- 71 Stingray
- Small Block 350
- Automatic (3 Speed)
- TH400 Transmission
- Had AC at one time, not worked since I have known of the car. Always driving with tops out anyway so have not attempted to fix.
- GymKhana Suspension
I am a mainly local cruiser, weekend driver and have determined I am going to go with the Champion Aluminum, but need to determine the correct one. I think it is the one in the photos. Can anyone confirm. . Also the overthinker in me is not sure about saddle mount or bracket mount? Just wondering what needs to be done to make sure it is in correctly. If anyone has experience with this and can help a newbie (with some experienced help) out it Would be much appreciated
Here is what I am looking at.
If more info is need please let me know.
Other issues which I can post separately if needed - Oil pressure, clock and temp Temp gauge also not operating.
Thanks everyone
if the vac mod doesn’t help then it’s probably slipping in and out of third. Let off accelerator, no load, shifts to third, as soon as you get back into it, it slips/can’t maintain.
I have done a lot of research the last few days, still confusing!. However automatics, w A/C are different than Manuals. Also has integrated Trans cooler. Dewitt's not really in my budget at the moment unfortunately. I only drive it maybe couple hundred miles a year locally... so not trying to break the bank. I appreciate the response and will look into the AIM, sounds like a good resource.
Expansion tank with cap
My DeWitts direct fit radiator
Engine compartment view
Another view
Right hand side tank and lower hose
When you do replace it make sure you install all the seals required as this greatly helps the cooling capacity.
