Head swap
Old Sep 10, 2025 | 02:50 PM
78silveranni's Avatar
78silveranni
Default Head swap
I am considering replacing my stock 624 heads with Speedmaster 1-281-001-01 aluminum heads. My 350 motor is an L82. I would like to keep the original intake manifold and exhaust ram horn manifolds. I know that I need to change the pushrods to the 7.9" length and I am considering using roller tip rocker arms..... anyone here done this conversion? Any advice would be appreciated... thanks
Old Sep 10, 2025 | 11:42 PM
Rebelyell's Avatar
Rebelyell
automatic or 4 speed?
Are ya gonna keep the L82 cam & lifters?
Speedmaster fka Procomp has lengthy & checkered-past. Maybe they're sugar now, maybe shyt ? dunno. Better choice is Trick Flow Specialties.
Old Sep 11, 2025 | 10:09 AM
randallsteel's Avatar
randallsteel
Just my two cents….
why go through the trouble of swapping heads when you plan to keep the restrictive intake and exhaust?
Are you trying to improve performance? Or are you just swapping heads to avoid having to rebuild the stock ones? The latter is understandable.
probably over $1k for what, 30-40hp gain?
you can delete the cat for under $100 and get the same result.
Old Sep 11, 2025 | 10:49 AM
78silveranni
I am not looking for any extra power/performance particularly but just to replace the existing heads which we know are pretty dire......if anyone on here can give me any recommendations that would be appreciated.... thanks guys
Old Sep 11, 2025 | 12:43 PM
Dynra Rockets's Avatar
Dynra Rockets
many, many years ago I swapped to GM 128 aluminum heads on my 69 ZQ3 when the original heads were in need of attention. The swap was very strait forward. Just make sure the block deck surface is clean and flat. I used the factory 1990/91 L98 MLS headgasket @ .028". The swap got me a huge weight loss, higher compression and thus more low rpm torque with the smaller 58 cc chambers, and hardened valve seats so no more lead substitute. Still on the car to this day.
Old Sep 11, 2025 | 12:51 PM
randallsteel
I hear ya, I’ve personally never used speed master heads, so I can’t speak to the quality.
Ive used edelbrock estreet #5089 several times along with trick flow.
It is very likely you will need .1” longer hardened pushrods, you can buy a pushrod length checker tool.
I personally don’t think the roller rocker arms are worth it on a mostly stock motor. A properly setup stamped steel rocker set will last you many many miles.
Old Sep 11, 2025 | 01:15 PM
Piersonpie's Avatar
Piersonpie
I took the gamble on Flowtek heads on my L48 with the understanding that they’ll be temporary before an entire engine swap. Two years later I haven’t had any issues, but like the Speedmasters they’re a foreign casting that’s assembled in the US, allegedly. If you only plan on doing this once I would look into some of the brands that are known quality and have better customer support if you run into problems.
Here is something to consider. Blueprint engines will sell you just the cylinder heads they put on their engines. The runner size is a bit on the big side for a stock L82, but it will give you plenty of room to grow if you decide to do other engine modifications in the future, and will be leagues better than the heads you’ll be taking off.
Old Sep 11, 2025 | 04:04 PM
jb78L-82's Avatar
jb78L-82
A couple of thoughts. I rebuilt my OEM L-82 completely in 2014, reconditioning the L-82 OEM connecting rods, reconditioning the forged L-82 crankshaft, Po rted the OEM L-82 intake, new 9:1 JE Forged Racing pistons, Howard Roller cam .525 lift/LSA 110/duration 219/225, and most importantly, for your cylinder head question (L-82 cast iron heads are 882's BTW), the only head to consider IMO if you plan on doing this once, AFR 180 64 CC heads which are hands down superior to just about anything else on the market, by a big margin. I also reused my Holley 4175 650 CFM spreadbore, comp cams roller 1.5 tipped rockers, with a 1 7/8 inch LTH headers with 2.5 inch duals, and Borla Type S C4 custom fitted mufflers
My L-82 355 makes about 450-460 Gross HP now, pretty much untouchable by any SBC Gen 1 motor.
Old Sep 11, 2025 | 04:15 PM
ZIOGEO's Avatar
ZIOGEO
I did this swap 18 months ago on a 73 L82. I used the Edelbrock e-Street heads and the Crane roller tip rockers 1.5:1 I think. I used new (longer) push rods and new lifters but everything else remained stock. The e-Street heads dont have the exhaust crossover for the intake and they dont play nice with roller cams.
If I were to do it again, I would go with similar closed chamber aluminum heads but ones that have the crossover port and roller cam ready.
Old Sep 11, 2025 | 05:11 PM
randallsteel
450hp with only 9:1 and .52 lift???
Request dyno sheet or 1/8 or 1/4 mile slip to support?
Old Sep 11, 2025 | 05:46 PM
HeadsU.P.'s Avatar
HeadsU.P.
Yea, really.
There are four things in a man's life that are grossly overestimated:
Size of their bratwurst.
The fish that snapped a line.
Annual income, without IRS looking.
The H.P. of a rebuilt engine.
Old Sep 11, 2025 | 06:27 PM
Rebelyell's Avatar
Rebelyell
dollars to donuts, the only dyno it's been on is the desktop variety. Seems a separate builder assembled his short block.
Old Sep 11, 2025 | 09:38 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
If you are keeping the stock pistons, I would get the smallest chamber size you can get, to increase the compression as much as possible.
The stock 9:1 is very low. Emission era.
Multiple TQ & HP benefits.
I think it is Trickflow and maybe some others that have 58cc heads.
Old Sep 11, 2025 | 11:52 PM
OMF's Avatar
OMF
Originally Posted by HeadsU.P.
Yea, really.
Now that’s damn funny
Old Sep 12, 2025 | 04:03 PM
augiedoggy's Avatar
augiedoggy
Right now... these are the best value for budget performing heads. they are th same castings as the flotek heads there are some you tube videos reviewing them. if you do get them, depending on the cam your running I would swap the springs.
https://www.vevor.com/cylinder-heads...hoCq2cQAvD_BwE
Old Sep 12, 2025 | 04:49 PM
jb78L-82's Avatar
jb78L-82
I was asked to comment about my heads and combo by another forum member that saw this thread but I forgot why I walked away from the C3 forum for a number of years, until most recently.
Thanks, Gentlemen, for the reminder, for me not to bother any more, moving forward on certain threads. No problem.
Enjoy...............
Old Sep 12, 2025 | 05:00 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
With ALL heads, you get what you pay for
To Head swap
Old Sep 13, 2025 | 10:23 AM
augiedoggy's Avatar
augiedoggy
There is truth to that.. to a point. but flow and performance tests between the heads I linked above and the brodix heads they area clone of resulted in the opposite with the chinese vevor/flotek heads actually outperforming the identically sized version brodix heads. Im sure there are better quality valves and guides out there and for some the additional cost for that hardware will pay off but not for everyones situation and when compared to the stock heads and hardware they are still an upgrade. The thing is, With heads and many performance auto parts its a shell game with white box generic parts being repackaged and rebranded and marked up accordingly so you dont always get what you pay for.
I bought a different set of bare chinese castings and loaded them myself with brand name hardware for about $750 and they work well on my engine. I cant brag about having $2000 heads but I dont care too either. Of course I could have also bought the exact same castings I have now from AFR... If I didnt want to learn how to assemble and set them up myself I would have. Today? Id buy the vevor heads and replace the springs and maybe seals.
Old Sep 13, 2025 | 01:39 PM
Rebelyell's Avatar
Rebelyell
Castings are one thing, But
More often than not, broken valvetrain parts n pieces leads to wrecked motors.
Unless you've got the inside straight and just won a big lotto, don't run no-name Asian valvetrain that's priced too-good-to-be-true.
If you win a valvetrain gamble, that'll be sweet ! But, if you don't
Old Sep 13, 2025 | 08:10 PM
HeadsU.P.'s Avatar
HeadsU.P.
The problem in the aftermarket parts world is too many companies using a common / likeness name.
This adds to misinformation / mistaken identity.
For example:
ProComp
ProFlex
ProForm
ProFlow
ProTech
ProMaxx
Should one, just one, of the above parts fail, they all may get bad feedback.
For example again:
Social Media says that Pro-somethings are no good.
Internet says Pro-somethings are awesome.
I am not a big fan of spending $2,000 on heads just for cruising the streets. Money NOT well spent.
A wise man says with anything priced from dangerously low to outragesly high:
Pick in the middle.
