Smog pump conversion for PCV evacuation
Old Sep 11, 2025 | 01:36 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Default Smog pump conversion for PCV evacuation
Im considering using a smog pump hooked up to my valve cover to use a a PCV pump. I dont need to draw a vacuum like a racing engine uses for negative pressure, just evacuate the gases. Has anyone done this. I found referneces in other forum,s, just seeing if anyone has done it here. Probably going to post a WTB as well.
Old Sep 11, 2025 | 02:21 PM
MelWff's Avatar
MelWff
Why not connect PCV to intake and use an oil catch can if that's your concern?
Old Sep 11, 2025 | 08:12 PM
Rescue Rogers
Ahhh, hello. Its me. THIS intake.
Its individual runner. All the stainless lines that go to the red and blue manifolds are vacuum lines connected to each cylinders runner to concentrate the combined vacuum. Its only 10 inHg at my gauge because I believe the PCV might be too big of a leak. Im hoping to remove the PCV system from them and use the pump thus creating more vacuum for my advance and headlights. Ive got 580 hp so i can spare a few for a pump.
Old Sep 11, 2025 | 08:36 PM
Bikespace's Avatar
Bikespace
After pulling the crankcase gases out with the smog pump, where does it go? Through a filter and into one of the air cleaner assemblies?
Here's a thread with a 12V solution, and some 15 year old links.
https://www.lightningrodder.com/thre...-inside.42933/
I see you have an alternator. Where would a smog pump go?
Old Sep 12, 2025 | 05:24 AM
Rescue Rogers
It would go where it was from the factory .
The gases would go to a catch can with a filter on top. Plenty of the crankcase vent setups out there for racing. They are about $1500 to start and are only good for a seasons worth of racing, so maybe 100 miles
Apparantly Thunder Racing is closed. If they had an electric vacuum pump for sustained use I would have gone that route. Electric is better, no one eles has one
Old Sep 12, 2025 | 07:14 AM
Bikespace's Avatar
Bikespace
Here's one at Speedway (with a catch can, though you might want to spec your own).
https://www.speedwaymotors.com/12-Vo...nk,482022.html
Speedway also has some expensive belt-driven Moroso vacuum pumps, if you want to go the smog mount route.
Old Sep 12, 2025 | 11:55 AM
Rescue Rogers
Thats for a brake booster. I got excited there for a moment
Old Sep 12, 2025 | 11:57 AM
Rescue Rogers
It would have to be rated for a constant duty cycle and oil proof since its drawing possible engine combustion gases and oil vapors. What ever may squeak by the rings and any oil mist whipped up from the crank spinning 6000+ rpm
Old Sep 13, 2025 | 08:36 PM
Bikespace's Avatar
Bikespace
That's unfortunate.
It looks like CVR, and Holley, sell expensive versions of a "smog pump" to run off a pulley. Hopefully your used GM smog pump works out!
Old Sep 13, 2025 | 08:39 PM
Rescue Rogers
Thanks........theres all sorts of expensive routes, Im hoping this works, it only needs to draw enough to get the vapors, Im not trying to seal the seals with high vacuum. ANd those pumps are rated for one season of use
To Smog pump conversion for PCV evacuation
