1982 Starter Clicks but doesn’t start
Old Sep 23, 2025 | 07:04 AM
ffarina's Avatar
ffarina
Default 1982 Starter Clicks but doesn’t start
Starter is 1998241 2013 and when I first try to start it it clicks and that’s it then I try again and it does start. I am just trying to fix it before I get stuck
somwhere. Does the solenoid only need replaced or the entire starter?
If it’s the starter is the AC Delco replacement better or the Remy replacement ?
Old Sep 23, 2025 | 07:08 AM
Piersonpie's Avatar
Piersonpie
Have you tired cleaning and tightening all 4 battery cable connections? 2 at the battery, 1 at the starter, and the other grounded to the frame.
Old Sep 23, 2025 | 08:19 AM
rgsGarage's Avatar
rgsGarage
Default Ooops, thought this was on the C2 Forum
If you are looking to replace it and are not concerned about originality, I went with Powermaster, the PowerMax Starters 9202 to be exact. It is smaller, lighter, and works amazingly. It was a direct replacement.
EDIT: SORRY, I thought this was on the C2 Forum.
Last edited by rgsGarage; Sep 23, 2025 at 08:22 AM. Reason: Ooops, thought this was on the C2 Forum
Old Sep 23, 2025 | 10:17 AM
pltmgr's Avatar
pltmgr
After checking and cleaning all the connections as suggested if the problem still exists Id rebuild the solenoid which should be fairly easy to do. I cant recommend a brand- I bought a solenoid rebuild kit on Amazon and it only fit after modifications. Make sure your battery is good as well.
Old Sep 23, 2025 | 11:09 AM
ffarina's Avatar
ffarina
Thank you for the suggestions. I will start with checking all the cables first.
Old Sep 23, 2025 | 07:03 PM
carriljc's Avatar
carriljc
Good call. I'd just remove, clean, and retighten the battery terminal connections before anything else.
Old Sep 23, 2025 | 07:18 PM
HeadsU.P.'s Avatar
HeadsU.P.
ffarina,
As others have mentioned your solenoid clicking issue is 90% of the time:
A really poor GRD. The solenoid is getting juice to activate it, but a poor GRD cancels some amps.
The solenoid also sends the 700 or so cranking amps to the starter.
The rear will have be put up on jackstands to locate the batteries NEG GRD at the frame. That location gets all the road grime, rust, corrosion, etc.
It's prone to offer electrical issues.
Those old Delco starters will out-live 3 solenoids. The solenoid does all the grunt work while starter is just along for the ride.
The solenoid is activated all the time the IGN key is on. The starter is not.
You can pull the starter and replace just the solenoid, inexpensively ($28). If you do buy a new solenoid, look for heavy duty or a unit with a brown end-cap.
That is ceramic and able to handle the exhaust pipe heat better.
A starter wrap, shield or blanket is always a good idea. Especially when headers are involved.
If you elect to pull the starter, tag all solenoid wires with masking tape / Sharpie for future reference. Better yet, take a picture.
Don't forget to disconnect the batt first.
Old Sep 23, 2025 | 08:52 PM
ffarina's Avatar
ffarina
Great information. Thank you all.
Old Sep 24, 2025 | 07:40 AM
7t9l82's Avatar
7t9l82
I strongly recommend changing the battery to frame ground cable if it hasn't been already. Also these new mini starters work great
Old Sep 24, 2025 | 07:44 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Have you load tested your battery? 90 percent of the car a starter goes, click, click, click. It's a poor battery. Then cables. Then starter
Old Sep 24, 2025 | 08:16 AM
ffarina's Avatar
ffarina
I have not load tested the battery. I did take a voltage reading and it reads 12.4V.
Old Sep 24, 2025 | 09:30 AM
HeadsU.P.'s Avatar
HeadsU.P.
Ok, good.
I just traded in a battery showing 12.4V.
That's not what starts the car. It's the Amps that start the car.
(My battery amps were at 40% of CCA.)
Old Sep 24, 2025 | 10:18 AM
old stingray's Avatar
old stingray
As 4-vettes suggested get the battery load tested first next check all battery connections including the ground before replacing the solenoid.
Old Sep 24, 2025 | 11:15 AM
ffarina's Avatar
ffarina
Right. Ok I will do that first.
Old Sep 24, 2025 | 02:59 PM
Rebelyell's Avatar
Rebelyell
For most folk, the Remy modern Permanent Magnet Gear Reduction replacement (or similar) is better,
And I cannot tell which starter you have; that po excuse for a link doesn't work for me.
Old Sep 24, 2025 | 03:26 PM
ffarina's Avatar
ffarina
I believe ACDelco and Remy were the same company at one time. But I have seen reviews that agree that the Remy is better. Delco is made in China and Remy in France. Thanks.
Old Sep 24, 2025 | 09:35 PM
Rebelyell's Avatar
Rebelyell
Look into Charles Kettering as a Founding Father; fascinating career.
https://en.wikipedia.org/wiki/Charles_F._Kettering
Yes, Delco-Remy was one company that was for decades a division of GM; finance agreements, fortunes, world politics and reliabilities change. Similar for AC Delco. China is a relatively recent "complication".
Remy spirits are French, Remy starters for chevrolet are not.
Throughout all of C3 relative short history, D-R was headquartered at Anderson, Indiana USA.
http://www.delcoremyhistory.com/
To 1982 Starter Clicks but doesn’t start
Old Sep 24, 2025 | 10:00 PM
ffarina's Avatar
ffarina
Interesting - thanks for all the responses.
Old Sep 24, 2025 | 10:45 PM
Way's Avatar
Way
Did you get it to turn over & start?
Old Sep 25, 2025 | 08:47 AM
ffarina's Avatar
ffarina
It starts after the second or third try. The first try is just a dead click and then the second or third try - it starts.
