radio circuit?
Old Sep 28, 2025 | 11:10 AM
tlwjkw's Avatar
tlwjkw
Default radio circuit?
'78 radio circuit? yellow comes hot with switch but goes off in a few seconds? turn switch off and back on it jus repeats sequence.. on for a few seconds then goes off again.. red is constant hot... don't have a schematic to trace origin of yellow.. anyone?
Old Sep 28, 2025 | 12:53 PM
tlwjkw's Avatar
tlwjkw
only one yellow.. its in tha same harness along with all tha rest of tha radio wires.. its supposed ta be a "switched (key on)" hot... it is for a few seconds!!
acts like it may be from a relay thats dropping out for whatever reason?? dono....
Old Sep 28, 2025 | 04:11 PM
Redboat's Avatar
Redboat
Here you go
https://www.corvetteforum.com/forums...or-anyone.html
Old Sep 28, 2025 | 04:27 PM
tlwjkw's Avatar
tlwjkw
wow!.. is he still an active member?..
Old Sep 28, 2025 | 04:29 PM
bmotojoe's Avatar
bmotojoe
Here are 2 drawings for your 78...
Second drawing is with power antenna option...
Old Sep 28, 2025 | 04:44 PM
tlwjkw's Avatar
tlwjkw
got something hay-wire.. tha yellow that shows to originate at tha fuse block thats supposed ta stay hot when key is in acc and/or jus "on".. it stays hot for 2/3 seconds.. turn key off then back on gets same scenario???.. haven't been able ta worm my way to tha fuse box and check it there yet so will try it tomorrow.. guess i need ta find out where it (20 amp fuse at fuse block) gets its power from???
looks like it gonna have something ta do with a power ant. relay which i should have but don't.. its a permenant ant..
Old Sep 28, 2025 | 04:54 PM
tlwjkw's Avatar
tlwjkw
this thing is an electrical mess from others that added and took away different junk.. jus gonna take some patience that i'm runnin' short on.........
Old Sep 29, 2025 | 12:55 AM
tlwjkw's Avatar
tlwjkw
its really got me scratchin' my a$$ now.. found a red/blk (supposed ta be yellow?) in radio male end of factory harness thats switched power??? can't find it on any of tha drawings i have right now
correction its a PINK/blk.. not RED/blk..
Old Sep 29, 2025 | 01:09 AM
bmotojoe's Avatar
bmotojoe
Before you unravel the harness wiring back to the fuse panel think about this...
There are NO timed circuits at the fuse panel...
You have switched power on one half of the fuse panel and BAT power on the other half...
Having a stationary antenna mast now doesn't mean your car originally came with one, especially if a power antenna failed and a stationary mast was the replacement...
At the radio power plug, how many wires does it have 3 or 4?
If you look at either of the 2 drawings I provided find C126 C= connector, that is the power plug to radio part of main dash harness...
If your car originally had a power antenna there would be 2 yellow wires at the main power plug C126...
Here is a photo of what I believe your 78 radio connections should look like, I have a 77 so I can't be sure...
The 2nd Yellow wire at the radio power plug would have been part of the power antenna harness and lands at the ANT cell of the radio power connector C126
Old Sep 29, 2025 | 01:11 AM
bmotojoe's Avatar
bmotojoe
Take your time, we will figure this out...
Can you get a photo of your fuse panel?
I know its not the easiest to do...
Old Sep 29, 2025 | 01:14 AM
bmotojoe's Avatar
bmotojoe
Here is a link to the replacement radio power/speaker harness...
Look at the Black connector does your look like that?
https://www.lectriclimited.com/produ...ctor-radio-15/
Old Sep 29, 2025 | 01:25 AM
bmotojoe's Avatar
bmotojoe
I have looked through the 78 electrical troubleshooting manual and I can't find any Red/Black wires...
Pink/Black several
Old Sep 29, 2025 | 01:36 AM
tlwjkw's Avatar
tlwjkw
no where close.. factory "male" end has no yellow, no ant. no relay, colors as follows:
gray
pink
pink/blk
blk
blk
brown
purple
orange
white
blue
there is NO yellow.. i'll get a coupla pics..
Old Sep 29, 2025 | 01:40 AM
tlwjkw's Avatar
tlwjkw
Pink/Black several
yeah, my mistake its pink/blk.. its a switched hot in this harness???
Old Sep 29, 2025 | 01:53 AM
bmotojoe's Avatar
bmotojoe
Here is a drawing containing 2 pages I cropped together...
Old Sep 29, 2025 | 01:55 AM
bmotojoe's Avatar
bmotojoe
I get up early, I will see what you posted in the morning...
Hang in there, patience prevails....
Old Sep 29, 2025 | 02:13 AM
tlwjkw's Avatar
tlwjkw
To radio circuit?
Old Sep 29, 2025 | 07:56 AM
bmotojoe's Avatar
bmotojoe
1978 was the last year for the AGC glass fuses, so your 78 fuse panel insides will look identical to my 77 except for a few wire color changes...
#10 Yellow wire is the outgoing side of Radio fuse...
Your #11 wire will be White not Yellow as mine is...
You can see the main BAT buss I labeled #12 (Right Side In Photo), and the left side would have 3 different switched sides 13 - 14 - 15
Old Sep 29, 2025 | 08:03 AM
tlwjkw's Avatar
tlwjkw
i have no 11 or 12... 10 is yellow but no yellow at radio plug.. pink/blk at plug is switched..
fused panel is just above tha clutch pedal...
Old Sep 29, 2025 | 08:12 AM
tlwjkw's Avatar
tlwjkw
got to get more light on these wires.. colors are somewhat faded and i'm real old....
