1978 corvette
Old Sep 29, 2025 | 09:43 PM
burst's Avatar
burst
Navigator
Default 1978 corvette
Hello, I’m having a lot of trouble trying to get my 1978 corvette running. I replaced the pump, rubber fuel lines, the hard fuel line going from pump to carb. I also replaced all the spark plugs and tested them. I also pressure tested the fuel pump and it seems to be around 8-9 psi. However, the car won’t start unless I manually pump the accelerator a few times and then the car dies. I also replaced the fuel filter. I would also like to mention I did open up the carburetor to clean it out and replace the gaskets.
Old Sep 29, 2025 | 10:04 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Pics of the engine from both sides without the air cleaner may help diagnose...
So it fires up but won't stay running, even if you pu the accelerator lever?
What carb do you have?
Has the car ever run while you've owned it?
Old Sep 29, 2025 | 10:09 PM
burst's Avatar
burst
Navigator
I can get some photos when I get back home. But to answer some of your questions I have a quadrajet 17058504. The only time the car seemed to run was when I first got it and installed the new fuel pump. It fired right up after I got it. Just never fired again after.
Old Sep 30, 2025 | 12:43 AM
hunt4cleanair's Avatar
hunt4cleanair
How old is the fuel? E-85?
Old Sep 30, 2025 | 12:47 AM
burst's Avatar
burst
Navigator
The old owner I bought it from said the fuel was from year and a half ago.
Old Sep 30, 2025 | 01:41 AM
Rebelyell's Avatar
Rebelyell
Dunno if that's your root problem, but that ol' cat pee will continue to cause problems; and will only get worse.
Suggest siphon all of it out, isolate it, and start over with all fresh non-ethanol.
Once all old cat pee is isolated, you might draw from it, only a gallon at a time and into your DD's nearly full tank.
Old Sep 30, 2025 | 06:01 AM
hunt4cleanair
I've got 5 gallons from my 78...and it takes forever to evaporate. I'll do this...a a gallon at a time.
Old Sep 30, 2025 | 09:10 AM
BKarol's Avatar
BKarol
carb is a 78, L48, 175hp, auto, a.c. Calif.
Is the engine compartment all original?
Old Sep 30, 2025 | 09:36 AM
barkingrats
That's certainly not helping. Ethanol regular only has a shelf-life of about 3-4 months before it begins deteriorating. That it fires with the old fuel means it's still volatile and should be able to continue running, but I'm thinking that it sat so long with old fuel that the carb passages are needing a deep clean.
Are you familiar with Lars Grimsrud for rebuilding and tuning Quadrajets to new or better? That would probably be the best option because you don't really know what other owners have done to it over the last 50 years.
BTW, there is also a filter in the gas tank -- called a sock. That could be plugged up with gunk too and not allowing full flow. Try retesting the fuel pump for flow volume into a container. You can have high psi but inadequate volume. I don't know the recommended specs for this but know others will chime in or you can look it up.
Old Oct 1, 2025 | 09:26 AM
ctmccloskey's Avatar
ctmccloskey
Getting that old gasoline OUT of that Corvette is the first thing I would worry about doing. As the guys mentioned above the Ethanol will cause the gasoline to go bad in just a couple months. If you didn't put any ethanol treatment in the gas then you are opening yourself up to multitude of problems.
Do Not try and burn the old fuel the way it is, it can gum up your carburetor in a short time. I like to use the fuel pump to assist me in emptying the fuel tank. Just remove the line going forward and divert the gasoline in to some 5 gallon cans. This is the fastest method for getting rid of the problem gas and not hurting the engine in your vehicle
If you try and burn the gas then you will need to put some new gas in to dilute the old stuff. There are fuel additives that help burn older fuel with no issues. One favorite is the famous "Mechanic in a Bottle" (at Home depot) which will rejuvenate old fuel and help you get rid of it without plugging up your carburetor. This works okay for me in most cases and then I use the Ethanol laden fuel and add it to my regular fill ups to use it up. This way we are not throwing away $3 a gallon fuel...
To 1978 corvette
