BPE 383 dyno sheet
Old Oct 1, 2025 | 05:41 PM
Lotventures's Avatar
Lotventures
Default BPE 383 dyno sheet
Hello everyone, i just received my Blueprint Engines 383 today. I am wondering if I need to be concerned about the wavy torque line on the Dyno sheet.
Thanks for any input
Old Oct 1, 2025 | 06:40 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Could be the cam, intake and the heads combo. I would be more concerned with why it falls off at 5500 rpm. Did you tell them you wanted an all torque motor and that you spend all your time below 5000 rpm? Did you say you wanted an RV cam? What Cam, heads and intake did you order with it?
What kind of driver are you? If you want a high torque motor that is going to spin the tires a lot and be really fun down low, be a rocket off the line and be a great cruiser, then it looks like you are going to get it. You just wont have a lot of top end which most folks dont use. Most people around here dont get much higher than 4000 rpm, ....ever
Old Oct 1, 2025 | 06:47 PM
Lotventures
this is the Blueprint Engines 383 crate motor. I purchased it just the way they advertise it, minimum 436 HP, 443 TQ, cam is 230/236/110, heads are 195cc intake/75cc exhaust, 64cc combustion chambers, and 2.02/1.60 valves,, but yes I will spend 100% of my driving time below 5000rpm's. Just a red light cruiser. I was just worried about the wavy torque line. It's definitely not the perfect arc
Old Oct 1, 2025 | 06:56 PM
Rescue Rogers
Flatter would be nicer but the display is 2000 to 6000 so its going to look worse that a 1000 to 7000 graph...it bunches the points on the graph closer so it looks steeper thanbit will feel. You will be fine. What intake is on it and will it fit under your hood?
Old Oct 1, 2025 | 07:02 PM
Lotventures
Thanks, thats good to know. The Intake is BPE's own source, a dual plane aluminum vortec knock off probably according to their part number. It will fit under my hood with a drop base air cleaner
Old Oct 1, 2025 | 07:06 PM
Rescue Rogers
Very good!!!!
Old Oct 1, 2025 | 07:22 PM
Piersonpie's Avatar
Piersonpie
Obviously the flatter the better, but keep in mind those waves are only around 25 ft/lbs. Being well above 400 from 2500 to 5000 should be a very fun engine.
Old Oct 1, 2025 | 07:30 PM
Lotventures
That is what I'm hoping for, a little spirited driving once in a while
Old Oct 2, 2025 | 01:17 AM
Rebelyell's Avatar
Rebelyell
HP curve is also peaky and within the very same ranges as TQ curve; it's just not so obvious. But the two closely coincide.
And the two curves always cross at approx 5250; but they always will.
*those other columns of numbers (not shown on graph paper) may reveal more; that's why they were recorded: fuel use etc.
** that dyno sheet is dated over a year and a half ago (01/20/24) ---- and you just received motor Fall 2025 ?
Are you certain THAT sheet truly represents Your motor ?
Old Oct 2, 2025 | 04:55 AM
Lotventures
Well that is BPE's promise
Old Oct 2, 2025 | 08:22 AM
pspicci's Avatar
pspicci
Look into your exhaust ports or through your sparkplug holes - should be easy to tell if the engine was actually run on a dyno or engine stand. it may be that they just never set the correct date on the dyno.
Pat
To BPE 383 dyno sheet
