PVC valve and crankcase pressure
Old Oct 8, 2025 | 06:32 PM
stosti's Avatar
stosti
Default PVC valve and crankcase pressure
Hi,
When I removed my stock manifold and carburetor I replaced it with an edelbrock 2101 manifold and an edelbrock AVS2 Carb. I am no longer using the stock air cleaner. I have a 10" unit now. The PVC valve is connected to the manifold where they told me to connect it. The other valve cover has a vent hole that connected to the stock air cleaner. Not it has a stand alone vent. I feel like since I did this the car uses to much oil. The car does not leak oil at all. It does not seem to be burning oil. Clear only coming out of the tail pipes. How do I know if I have correct crank pressure? The car has 26k original miles and the compression of all cylinders is normal. Valve stem seats were replaced a year ago because they were 45 years old.
Thanks,
Scott
Old Oct 8, 2025 | 08:31 PM
RocketJSquirrel's Avatar
RocketJSquirrel
2026 Corvette of the Year Finalist - Modified
2025 Restomod of the Year
It is much more likely that increased oil consumption is due to leaking around an intake port that didn't get sealed properly. The PCV system, all things being equal is working the same as the original setup. Check your plugs and see if you have oil fouling to try and pinpoint the location.
Old Oct 8, 2025 | 08:57 PM
stosti's Avatar
stosti
Intake manifold leak? Yes, a couple of plugs were fouled. They just tuned it up a month or so ago. Do those plugs point to the problem area?
Old Oct 8, 2025 | 09:12 PM
RocketJSquirrel
Quite possibly.
Old Oct 9, 2025 | 08:43 AM
stosti's Avatar
stosti
If the manifold was not sealed correctly wouldn't that be a huge vacuum leak???
Old Oct 9, 2025 | 09:12 AM
RocketJSquirrel
It could be a minor leak where it is not bad enough to cause drivability problems, but just sips oil at a slow rate.
It is not uncommon for an aftermarket manifold to have some mismatch to the head ports, especially if the heads have been milled at some time in their life.
Old Oct 9, 2025 | 09:20 AM
stosti's Avatar
stosti
If it is leaking, it's not under the car...
Old Oct 9, 2025 | 09:29 AM
ctmccloskey's Avatar
ctmccloskey
A leaky intake manifold could pull oil from the crankcase and burn it. It happens more often when the intake is removed and replaced improperly.
It happens when the RTV used to seal the intake to the block breaks free and allows a leak to occur. I have seen people pulling and tugging at the RTV on the China Wall and this can cause the vacuum leak to occur.
The oil is pulled into the combustion process and it gets burned up. This will cause oil consumption at a slow rate and will leave your garage floor clean as a whistle.
Old Oct 9, 2025 | 11:55 AM
stosti's Avatar
stosti
How do I know if this is the issue?
Old Oct 9, 2025 | 03:14 PM
RocketJSquirrel
You will just have to pull the manifold and look. There should be traces of oil in the intake ports. At the same time, look at the impression on the gasket to see if there is a thin margin that would indicate a mismatch.
Old Oct 9, 2025 | 09:00 PM
REELAV8R's Avatar
REELAV8R
Take a look inside the PCV hose that goes to the manifold first. If there is oil in that hose the PCV may be your source of oil.
That may indicate inadequate baffling inside the valve cover.
To PVC valve and crankcase pressure
