4.11 to 3.55
Silver Sport guarantees there are no tunnel modifications, and he would have the choice of overdrive gears.
The OP could retain his quick light to light acceleration and could reduce his highway cruising rpm’s by 900 rpm.
Since he already has a manual transmission the conversion would be simple and something he can do himself in his garage.
He would also end up with a new transmission, clutch, pressure plate, throw out bearing, balanced drive shaft, transmission mount and u joints all included.
This seams like the best option.
A CR M21 box needs a 411 to have the exact same 1st gear ratio overall.
2.20*4.11= 9.1
2.54*3.55= 9.1
But since he currently has 411s:
2.54*4.11=10.4
That is pretty deep.
How big is the cam duration?
That comes into play here also.
It is the close ratio boxes and their frequently used factory minimum 3.70s that are kind of soft/slow off the line.
2.20*3.70=8.1 overall
Those really benefit from 411s. Or even better, a wide ratio box.
Wide ratio boxes are just a little more rear gear tolerant.
However, it should be noted that during the '74 C3 model year, Chevrolet changed from the Muncie to the Borg Warner Super T-10 4-speed and with that change first gear for the close-ratio version went from 2.20 to a deeper 2.43. This change was warmly received at the time.
Therefore, in the way of comparison, the math looks like this.
'68-'74 Muncie close ratio first gear: 2.20*3.70=8.1 overall
'74-'79 BW ST10 close ratio first gear: 2.43*3.70=9.0 overall
The wide ratio first gear ratio also got deeper, from 2.52 to 2.64.
However, I'm assuming the OP wants to keep his current, perhaps original, transmission.
1979 L82 M21 3.70 FE7
Classic White / Doeskin
<SNIP>
Earlier I had an M20 with the 336s with a L48. A better cruiser, all around, but a little slower off the line.
But worked with the milder motor, that one did not rev as well.
I had 308s with a M20 in another L48. That one had really long highway legs, but it was so slow off the line.
I’m running 3.08’s in the rear, my 5 speed has a 0.82 overdrive and a 2.87 first gear ratio.
My 496 made 480 ft lbs of torque at 2800 rpm which was where to dyno started recording data and it made close to 600 ft lbs of torque at 4800 rpm.
The engine continued to build hp through 5800 rpm and that’s where we shut it down.
I really wouldn’t want a 3.36 or a 3.55 rear gear.
The 3.55 gears will give you a decent drop in highway rpm over 4.11. Personally I would not even want 3.73 without overdrive, I like to go 65,70 mph and still hear the radio
Fyi, I'm not a mechanic and only doing smaller stuff on the car myself, plus english is not my main language, so I might need a dumbed down answer. I do understand basic mechanic terms though
With a 255 tire (27.1inch) and 4.11 your tach would be reading 4100rpms at 80mph. With 3.55 it would read @3500rpms.
3:55 is used with a 3 series posi case
411, from GM or from the period (60-80's) uses a 4 series case. The standard 4 series gear is thinner, the old hot rod way when converting to a 4 series gear was to go to your local speed shop and by a spacer. It was a bad idea, but it saved guys money up front over going to the local chevy parts counter to buy the correct 4 series posi case. I will guess that the spacer was under $10 and the new Eaton USA made posi was $200 in 1970's money. That was a lot. Over time the load on the ring gear caused the bolts to loosen and back out, which caused diff failure.
Tom Watt had 4 series gears made by US Gear thicker to eliminate the spacer and not cause a problem. That goes back 25+ years now. Today, Tom's and US Gear are gone. Yukon makes a think 411 vette gear today and charges more for it.
You can still find GM 4 series gears used and they may be in good condition but there were two designs, one was junk and broke, the other is the revised version. Many selling them have no clue what they're selling. Many people rebuilding them today are questionable as well. I have called some out and have answered many phone calls from guys who bought exchange diffs from some places that were bad. Finding a good 4 series posi case is a crap shoot as well because they also had revisions, some were junk, some were good. Most today are worthless because fewer and fewer want 4 series gears and the only new one is from Yukon. All new gears today are imported, mostly from China.
Place the rear of the car on jack stands.
Parking brake off, transmission in neutral.
Mark the driveshaft with paint or chalk or crayon.
Rotate one one of the rear wheels by hand one turn while counting the number of times the driveshaft turns.
Anyway, the real ratio isn't too important, as it clearly is over 4.00 ratio, and I wanna have a 3.55 as it came from factory. My question was whether I could use the 4-series carrier with the 3-series gears, it seems as if they do not fit. Thank you everybody for helping out!
