I know there is a lot of threads covering this topic but I have what I think is an strange issue or may be normal. My car went completely dead over night but track it down to leaving the clove box open, really didn't think it should drain the battery over one night so I decided to use the test light and check if there was any other items draining the battery. I found the light would pulse on and off, it was like turning on your blinker. When I pull the curtesy fuse it would stop. I have a quarts clock so I disconnect, but it wasn't the clock. Turns out my radio is causing this issue, its just a JVC so nothing special. I replaced the radio with another JVC, didn't want to change the plug, double checked the wires are correct, so the constant power is going correctly to the correct wire, and the ignition switch is also correct, ground looks to be good as well. Any ideas is to why the test light pulses (its not the LED light)? Is this normal?
Ok, I'll use a amp meter, to check how high the draw goes. But it seems strange I would get any fluctuation in power. I don't have the timer for the lights. When I close the doors the lights go off, no delay.
I hooked up my multimeter, I know it only went to 200ma but if all was normal it shouldn't have an issue reading the milli amps. It went into overload, so I think I have an issue. any thoughts?
Leave the amp meter connected for at least 5 minutes to let whatever circuits to charge up. In my experience most amp meters that are rated to read 0 to 200ma will read higher than 200ma but amp meter with a 0 to 10 or 20 amp scale would be preferable. A 200ma draw is about what a glove box bulb (194) draws.
I would have to pick up a new amp meter, but I can tell with the test light it illuminates every 4 seconds without fail only when the radio is connected. I triple checked the wiring and it is 100% correct. I guess we need to see what the draw is to be sure. But would draw power every 4 seconds. Bulb goes dark then lights up every 4 seconds.
Update, I was thinking maybe I had the curtesy delay and it wasn't working, broken. When I tried to find out where it would be on a 76, since 77 had it above the steering column but could not find any real documents for the 76. I did find one place that said it was behind the glove compartment. I don't even think the 76 had a delay for the interior lights. Anyway there was a module (HOBBS 6258257). When I pulled it out the I have no drain, light stays off. Looking at the part number shows it to be a seat belt buzzer. Anyway I have no idea at this point, but that seams to be the culprit. Since I have no switches to say if my seat belts are connected or not I will leave out the module. Why this only happens with the radio connected I have not figured out, maybe someone can elaborate. But I think it is fixed.
sorry, false alarm. Its not fixed. Not sure why it stopped for a short time. So still have the issue with the module out. Waiting on a new amp meter, hopefully in a couple days I can post the draw.
I've seen many radios that pulse a red LED in the car, either as part of the real anti-theft system, or a fake one.
Where are you connecting your ammeter? My Fluke will do 10 Amps, but I'd never connect it to my car. I use a Fuse Buddy instead (Amazon link, may require some effort to make work with glass fuses). 100 mA or less? I don't care about that. I have a battery quick disconnect instead. If you have a bigger drain, and you can't find it in a fused circuit, it is likely the alternator.
This is what I found with the AMP meter.
Set it at 10 AMPS, connected the meter in series. (black wire disconnected form battery, touched negative side of battery with one lead then the other to the disconnected battery wire).
After a couple of seconds I get the spike to .3 amps. Then it slowly drains down to .01 (I assume the quarts clock).
It doesn't fluctuate after that just stays at .01 and I also connect light tester and it stays off.
Seems like the amp meter drains what ever is causing the spike.
But it comes back once I disconnect the amp meter. So I definitely have some kind of problem but this is only when the radio is connected.
I know the radio is connected correctly.
You're good with the 10ma draw, nothing to worry about. The 300ma when you first connect it are just charging the memory circuits. That will happen every time the battery is reconnected.
