Raising octane? AVgas?
Old Nov 1, 2025 | 12:55 PM
Golfobsessed's Avatar
Golfobsessed
My engine builder told me that they will run some race fuel through their engines during the final dyno run.
He said that the race fuel will help preserve all the carburetor components.
He told me that they realize that many hot rod engines may not be run for a couple years after they leave their shop and this helps the customers.
He sells the fuel and said to run some through the system if I planned to store the car over the winter.
primarily exactly why he used it, thank you
Old Nov 1, 2025 | 12:56 PM
Golfobsessed
Originally Posted by Rebelyell
If you end up with permission from General Aviation to purchase AVGas. However, if you can Only get it via filled containers; jugs like linked below from speedway are good. Many others sell em too.
5 gallons each, good cap with NO uncooperative safety apparatus, and a long flexible plastic spout. This type jug ubiquitous around local race tracks.
You can get em in several different colors. This type configuration is easiest to use and stacks-stores-nestles-travels conveniently.
https://www.speedwaymotors.com/Utili...ors%20Products
perfect and thank you, I knew I couldn't pump it directly into the car from there and would need a specific container... and im 20 minutes from Speedway
Old Nov 1, 2025 | 12:58 PM
Golfobsessed
Originally Posted by VERYSOON
Golf
Coming at this from a different direction:
My 69 has a 10.25 to 1 CR which runs great on 91 non-ethanol. Here is the setup as suggested to me by the great Lars.
I installed Lars Vacuum Advance Corrector Plate with a new B26 vacuum canister (Napa VC1765). Idea is to limit vacuum advance but let it come in at lower vacuum level. I have a total of 34 mechanical with advance of 12 giving a total advance of 46. The limiter only allows 12 degrees additional vacuum advance. You want to avoid having a total of over 52 degrees. Idle is at 750. Runs like a raped ape. No ping or buck at part throttle. (Thanks Lars. I hope I got this right.)
VS
thanks VS, I am going to set my total timing today and gonna let the currect fuel run down a bit more before trying just good pump gas and see what happens
Old Nov 1, 2025 | 01:00 PM
Golfobsessed
Originally Posted by barkingrats
I've never felt the need for av-gas, so have never bought any. They will (should) flat out deny your sale if you try to put it directly into a vehicle - it's a federal violation. That means filling gas cans at the airport and transferring to your car at home (in your closed garage, at night, after all neighbors have gone to bed, and lights off & wearing night-vision goggles).
My 2 big blocks have 10:1 & 10.5:1 and I run both on non-ethanol high-test (~93 octane) with no problems at my sea level elevation. The higher the elevation you operate, the lower the octane rating the engine will require.
thank you... I believe I will be ok with 93 octane as well after talking with prior owner
Old Nov 1, 2025 | 01:01 PM
Golfobsessed
Originally Posted by stingr69
My home built 10.4 C/R L46 ran fine on pump premium and might have ran on regular unleaded but I never tried. My 10.7 C/R stroker with iron heads runs great on pump premium but it is cammed and built for it.
My suggestion is to purchase a can of Torco on Amazon and carry it in the car with you, fill up with some pump premium and test it. If the pump gas works well, great. If it pings on a tank of fresh premium, add half a can of Torco. It works great on my supercharged LS3 for times when pump premium was not readily available. Regular octane pump gas will ping in that car. No downsides with Torco.
Old Nov 3, 2025 | 11:25 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
My blue-printed 70 LT-1 had a true 11:1 as cc'd. Shaved heads, block, etc. Not the 10.5-10.6 that is typical from the factory.
That said it did not like 93 Octane. It liked about 97. With an aggressive & optimum HP timing curve.
I retarded the initial timing back to 8*, for 32* total, and limited the vac advance degrees, and then it liked 93 Octane just fine.
Old Nov 4, 2025 | 07:07 AM
Golfobsessed
thanks leigh1322, I have not yet added gas since purchase, I set initial at 9 degrees and dwell at 30 just as a baseline to start and drive after tune up... starts and runs great but getting a backfire pop from carb after shut off from longer drives.
I had to travel out for SEMA but back home Thursday and gonna set a total timing to 36 degrees and see where that leaves initial... hoping to eliminate that developed backfire.
These heads were done years ago but only says "resurfacing" with valve part numbers and spring part numbers on invoice, no other info.
Once I set that total timing I will be adding 93 gas without the AVgas add and see how that does... I dont want to chase two things at the same time and want to eliminate that carb pop.
Old Nov 5, 2025 | 03:45 PM
theandies's Avatar
theandies
As a long time general aviation mechanic I can tell you I've run AVgas in my cars before as stated once drained from the aircraft it cannot be reused for aviation. I would put that gas in my car. Ran fine. One thing to note is AVgas has a blue dye in it so show fuel leaks. The reason why is if you tank (or other parts) is leaking and the fuel evaporates you'll still be able to spot the leak as the dye is still present and leaves a sticky blue streak where the leak was. This dye is not made to go through an automotive carb and could gum it up if used too often. Aviation carbs are designed to handle the dye. Something to think about.
Old Nov 5, 2025 | 07:01 PM
68/70Vette's Avatar
68/70Vette
Built a 1969 car with a clone L88 engine. I did machine 0.100 off the piston domes for an approximate 11.5:1 compression ratio. Anyhow California 91 octane didn't work....the pinging sounded like the anvil chorus from the engine. I started buying high octane AV gas from the Torrance airport. Happiness. The guy at the airport got to know me and eventually just pumped the AV gas directly into my car. Highly Illegal!!!! I'd fill up with 20 gallons of AV gas and then, say when I burnt off 1/4 of a tank, with 3/4 of gas in the tank, I'd fill up with pump gas. Then at 1/2 tank I'd fill up with pump gas. Using this technique, I could drive to Las Vegas and back...600 miles round trip. I was experiencing pinging for the last few miles.
I now buy racing fuel for my 68 hanger queen. I don't need the octane, but I DO want the alcohol free nature of the fuel. .
Old Nov 6, 2025 | 08:12 AM
cottoneg's Avatar
cottoneg
Like leigh1322 mentions, I had a 350/350 and from the factory was 11:1. When I first got the car, the engine was shot. So I rebuild it. The machinist did 1 ten thousandths cleaning cut on the heads. When the engine needed to be refreshed, another ten thousandths cleaning cut. I used to run Sunoco 93. It wasn’t enough. The forged pistons showed chips missing from detonation.
Old Nov 6, 2025 | 10:13 AM
Golfobsessed
Thanks guys, heading home today and will be playing with timing over the weekend and then adding gas to see how it reacts to straight 93 pump fuel
Old Nov 13, 2025 | 08:46 PM
SteveJewels's Avatar
SteveJewels
Toluene
Old Nov 17, 2025 | 08:38 PM
  #33
AZSTAR's Avatar
AZSTAR
Default Arizona.
Originally Posted by Golfobsessed
Thanks guys... I will make some calls to some smaller airports... im assuming I should tell them I need it for something else if asked.
I also have all documentation for the car and the the shop that did the heads years ago is actually still in business... i will go through paperwork to see if i can find specs on the heads rebuild
Only one airport in the Phoenix area that still will let you buy aviation fuel in a container chandler airport.
Old Nov 17, 2025 | 08:48 PM
  #34
Golfobsessed
Thank you... im in the very far north west valley and nobody out here selling AVgas nor can i get 93, I am not far from pleasant lake shell who sells 110 octane.
Going by the (% x octane) + (% x octane) I am mixing 1 gallon of 110 to 9 gallons of 91 to get me around 93 and working very well... I think the car is enjoying some fresh gas too
Thanks again.
Old Nov 18, 2025 | 10:21 AM
  #35
theandies's Avatar
theandies
Have you ever considered this?
Octane Boost
Old Nov 18, 2025 | 10:44 AM
  #36
1Hotrodz's Avatar
1Hotrodz
AvGas has special ingredients in it for Altitude and Temperature extremes. These are things an automotive engine does not require. Is it detrimental, IDK? But I would stick to mixing race fuel instead. Also one of the major ingredients, to boost Octane, in CAM2 race fuel is Toulene. I used to buy it (Toulene) in 5 Gal cans, but that was 35 years ago. Restrictions today on this stuff are much stricter. I think I mixed at 5-10% Volume.
Old Nov 18, 2025 | 11:28 AM
  #37
OldCarBum's Avatar
OldCarBum
If you have a marina near you, go by and see what type of fuels they are selling.
Back in the day, our drag boats and the off shore boats required high octane fuels and the marinas sold them right out of the pump.
Mercruiser sold several products over the counter for boosting octane, to help preserve fuel or dry it out if you encountered fuel with high moisture content.
Just a thought!
To Raising octane? AVgas?
Old Nov 18, 2025 | 01:48 PM
  #38
Eric P's Avatar
Eric P
this stuff works
VP Racing 29505 VP Racing Madditive Octanium Unleaded Concentrate | Summit Racing
Old Nov 18, 2025 | 02:12 PM
  #39
Rebelyell's Avatar
Rebelyell
Originally Posted by SteveJewels
Toluene
yup
retail about $100 - $120 / 5-gallon pail of tech grade Toluene.
Old Nov 18, 2025 | 08:12 PM
  #40
Golfobsessed
Thanks to all... I discovered I can't get 93 anywhere near me however I found 110 about 15 mins away, got a few gallons ($15 a gallon) and mixing it in 10% with 91 octane and happy with it... puts me about 93 octane, they keep the pump locked but I can walk in and they will come unlock it.
I've read good things about the VP racing octane boost as well as the Boostane but will just keep a gas can with the 110 after getting pump gas.
