Speedo not work
Old Feb 18, 2003 | 09:59 PM
79corvette's Avatar
79corvette
Default Speedo not work
I disconected my speedo cable from the tranny and hooked up the drill and the speedo did move, so I assume the problem is inside the tranny. I replaced the gear inside it and that did not help. Just to confirm what I think it is I am going to ask if it is the gear that gets "knocked" out of place in the tailshaft of the tranny causing the problems. If so, is this a hard job to do with the tranny in the car.
Old Feb 18, 2003 | 11:07 PM
wombvette's Avatar
wombvette
Default Re: Speedo not work (79corvette)
No the main shaft gear is not likely the cause. I would look at the cruise module or the cables. The cruise module is a common source of problems. The rotation of the cable is CCW.
Old Feb 19, 2003 | 06:34 AM
jerryp58's Avatar
jerryp58
I agree this isn't a common problem.
I thought it was the problem with mine so I replaced the driven gear.
I can say that mine was not a difficult job because I had the plastic gear that clips on versus the pressed on metal gear.
My gear WAS cracked, but I may have done that during removal.
As far as replacing the driven gear; there are a couple of good books out there with illustrations (I got one from the local library, but maybe they're on the Web too) but it basically goes like this:
Remove the speedo driven gear.
Remove the drive shaft.
Remove the tailshaft (4 bolts).
Remove the metal retaining clip for the plastic gear or "pull" the metal gear (that would be more difficult).
Replace with new gear & reverse the rest of the steps.
I already had my trans drained (for a shift kit) so I didn't have to deal with fluid dripping.
I also bought all of the new gaskets (tailshaft gasket, rear seal, driven gear seals).
When I finally got it back on the road, the speedo still didn't work; turned out to be a break at the CC transducer :rolleyes: But at least I have a new gear and gaskets/seals.
Good Luck.
To Speedo not work
