Fuel Guage issue
Old Nov 25, 2025 | 11:26 AM
Corvette80&alive's Avatar
Corvette80&alive
3rd Gear
Default Fuel Guage issue
I changed the fuel sending unit on my C3 because the gauge on the dash would not show full or empty. It just stayed around a quarter tank even when I filled the fuel tank. The gauge still reads 1/4. Did I waste time and money changing the sending unit? Is the Guage itself faulty and should I have changed that instead of changing the fuel sending unit?
Old Nov 26, 2025 | 11:22 AM
cagotzmann's Avatar
cagotzmann
Test the old sending unit's ohm's range. should be 0 - 90 ohms.
If it is then the problem is not the sending unit.
then you can test the gauge depending on year.
watch this
Bing Videos
Old Nov 26, 2025 | 11:56 AM
Corvette80&alive
3rd Gear
Thank you so much. I didn't know about the Ohms test. I'll try it. Thaks again.
Old Nov 28, 2025 | 10:15 AM
TommyFox's Avatar
TommyFox
I have the same problem on my 80. I have a bouncy needle so I replaced the sending unit. Still bouncy and won't read over a 1/2 tank. I'm going to replace the gauge soon when I get time.
Old Nov 29, 2025 | 04:47 AM
Corvette80&alive
3rd Gear
Can you let me know what happens after you change the gauge? Thanks
To Fuel Guage issue
