82 Differential Plug
Old Dec 16, 2025 | 04:23 PM
jthornton's Avatar
jthornton
Default 82 Differential Plug
I'm attempting to change the oil in my differential and the plug is not budging with a 3/8" breaker bar. The plug is the kind that has a 5/16" hex. Going to spray some break free on it. Just wondering if it's safe to use my air impact on low to try and break it free?
JT
Old Dec 16, 2025 | 05:09 PM
Piersonpie's Avatar
Piersonpie
I would try your penetrating fluid, and at worst heat before trying an impact. Of course keep in mind your gas tank is right above you.
Old Dec 16, 2025 | 05:13 PM
jthornton's Avatar
jthornton
As for heat I don't want to melt the plastic tag if possible. The bottle of limited slip additive does say to change the oil when it's warm so that might be an interesting thing to do when I can't drive the car right now. I want to change the oil before I put everything back in.
JT
Old Dec 17, 2025 | 11:25 AM
kanvasman's Avatar
kanvasman
Try a 1/2" bar. Or a lot of times when I have had trouble breaking a bolt loose, I try to tighten it first. I can't tell you how or why that works, but it has worked for me many times. Maybe it just breaks the rust loose.
Old Dec 17, 2025 | 03:15 PM
jthornton's Avatar
jthornton
I can't tell from the couple of photos I found of 80-82 differential plugs if it's a tapered thread or an O-ring seal. Anyone know what kind of plug the 80-82 has?
JT
Old Dec 17, 2025 | 03:37 PM
jthornton's Avatar
jthornton
I can answer both questions now, the plug has tapered threads and the impact just feathering the trigger to keep it low backed it out just fine.
Do you use any kind of sealer on the threads?
JT
Old Dec 17, 2025 | 05:08 PM
SEVNT6's Avatar
SEVNT6
I never have. I'd continue spraying penetrating oil around it & using a 1/2" bar like kanvasman said..
Old Dec 17, 2025 | 05:34 PM
jthornton's Avatar
jthornton
The plug is out the impact tool on low got it out just fine.
JT
Old Dec 17, 2025 | 05:36 PM
Rebelyell's Avatar
Rebelyell
JT
Thread Sealer on those tapered threads ?
Yes I do on plug's threads, Either some common hardware aisle pipe dope OR Teflon tape.
Neither should be absolutely necessary. However, it might weep without it. Yes, belt & suspenders.
Old Dec 17, 2025 | 06:03 PM
Piersonpie's Avatar
Piersonpie
A sealant will help yes, but if you don’t want to use that a small dab of grease or other lubricant on the threads will allow you to get more torque on it, and make it easier to take it out in the future.
Old Dec 17, 2025 | 06:15 PM
Rebelyell's Avatar
Rebelyell
Neither pipe dope or Teflon tape will hinder removing plug; not now nor ten years hence. The right tool for the job. And Both offer excellent lubricity.
Old Dec 18, 2025 | 05:47 PM
drwet's Avatar
drwet
JT
Yes. Teflon pipe sealant. And don't overtorque it when you reinstall it. Just good and snug.
To 82 Differential Plug
