Tremec Silver State 5 sp
Old Jan 1, 2026 | 02:18 PM
Taijutsu's Avatar
Taijutsu
Default Tremec Silver State 5 sp
Time to bite the bullet and buy 5 sp.
I've heard nothing but good about the Tremec Silver State combo.
I want to replace M21 in my 74.
I'm running 300 rwhp, nothing serious.
What is the bottom line for the conversion?
I tried search and it is useless! WTF
Thanks for the help.
Rick
Old Jan 1, 2026 | 02:29 PM
60 SHARK's Avatar
60 SHARK
Try Silver Sport Transmissions,,, not state.
they have YouTube videos and info. I put their 'perfect fit' 5spd kit in my '75 five years or more ago. Still loving it,, no issues at all. You'll be happy.
Old Jan 1, 2026 | 02:31 PM
Taijutsu's Avatar
Taijutsu
How much was your conversion?
I'm sure it has gone up?
Thanks for the info.
Fly skids up!'s Avatar
Fly skids up!
https://www.shiftsst.com/quick-quote
Old Jan 1, 2026 | 03:44 PM
Taijutsu's Avatar
Taijutsu
Thanks for the heads up.
I'm waiting for a quote.
I'm guessing about $4K.
I will post results.
Old Jan 1, 2026 | 04:01 PM
60 SHARK's Avatar
60 SHARK
I got my kit at thr right time. I called and they had a "open box " sale at the time. 5yrs ago. I got everything, including u-joints, yoke & drive shaft, to do the swap. . Less than $4k....... Today expect at least $2k more + shipping. Possibly higher. Do the quote,, or call in person.
SST #865/609/8187 M-F 8am-6pm EST
Old Jan 1, 2026 | 08:08 PM
socal_tom's Avatar
socal_tom
I just bought the TKX 5 speed with a clutch flywheel a drive shaft with the hydraulic throw out bearing kit, $6000 for everything
Old Jan 1, 2026 | 09:03 PM
Bikespace's Avatar
Bikespace
I'm guessing between $6K and $7K now. They make nice stuff, and are proud of it.
Old Jan 1, 2026 | 10:41 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
If you have a M21 now, you likely do not want or need the flywheel, clutch or hydraulic throwout bearing.
Old Jan 2, 2026 | 07:59 AM
TommyFox's Avatar
TommyFox
Do they make a conversion from automatic to manual?
Old Jan 2, 2026 | 08:09 AM
Bikespace's Avatar
Bikespace
Silver Sport Transmission makes two Tremec manual kits for the C3. One with a TKX 5-speed, and one with Magnum 6-speed. If you start with an automatic, they can provide the conversion kit which adds the third pedal, etc.
https://www.shiftsst.com/1968-1979-c3/c313
https://www.shiftsst.com/1980-1982-c3/c357
I'm not sure why they call out the 80-82 cars separately from the other C3s (driveshaft and trans crossmember are different), but there are the two links.
Old Jan 2, 2026 | 08:57 AM
60 SHARK's Avatar
60 SHARK
I've used Malwood clutch pedals before. I like having the slave inside, not in the eng compartment. Just a personal preference...
.Corvette (C3)1968-82 Under-Dash Hydraulics clutch pedal kit - MalWood USA https://share.google/DbBxXdgcFTbaE5o59
Old Jan 2, 2026 | 09:20 AM
Fly skids up!
I think it's the driveshaft. One for the iron case and one for the aluminum case diff's. Also they warn on the 80-82 cars the exhaust Y-pipe interferes with the transmission. Recently when I ordered a TKX for my Cuda and the driveshaft is no longer part of the kit. They give you paperwork to fill out asking length of the rear u- joint center line to the transmission and rear u-joint type (1350) after the transmission installation is completed and is ordered separately.
I don't recall what the shipping cost was but to Florida it was nowhere near $2000. It was something like around $300 FedEx and will be in the quote. It's not like a engine on a pallet shipped freight.
Old Jan 2, 2026 | 11:55 AM
68/70Vette's Avatar
68/70Vette
I have Silver Sport 5 speed Tremacs in my 68 SB and 70 BB. The overdrive works well with my 3.73 diff ratio. Really nice short throw shift feeling.
Old Jan 3, 2026 | 09:56 AM
TommyFox's Avatar
TommyFox
I don't see the bellhousing or 3rd pedals in the pic.Different kit I guess. Is the Z-bar reproduced or would I have to find a used one?
Old Jan 3, 2026 | 10:58 AM
60 SHARK's Avatar
60 SHARK
I thought you have a standard shift now,, you can use your bell housing and manual Z linkage if you don't want a hydraulic clutch.
Used Z linkage easily found for sale.
Old Jan 3, 2026 | 11:02 AM
Fly skids up!
Those kits listed are for existing 4 speed cars. They do have the parts for automatic to manual swap. They do not sell any mechanical linkage for the clutch. They do sell a hydraulic clutch setup.
To Tremec Silver State 5 sp
Old Jan 3, 2026 | 12:56 PM
Bikespace's Avatar
Bikespace
If you want a mechanical linkage, you'll have to DIY. They make their own, very nice, bellhousing. It's the same casting, but a different finish, for Gen 1 SBC vs LS. A kit is a kit, but they will help build what you need and fill in the gaps
Old Jan 3, 2026 | 01:03 PM
stingr69's Avatar
stingr69
I bought the conversion kit for my '80 from Silver Sport and they included the stock mechanical clutch linkage as requested. They will sell you whatever you need. Nothing you don't want.
I have a hydraulic clutch on my 2010 Camaro and it sucks. No way would I ever install a hydraulic clutch on purpose. There is no advantage IMHO.
Old Jan 3, 2026 | 01:25 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Here is my TKX order from 2021.
I have an original 4 speed car.
It breaks down every part you need.
The trans is different than less expensive "generic" ones you can find online due to the corvette specific shifter that is pre-installed.
I got no clutch, flywheel, or driveshaft.
I preferred to get those myself.
I see zero advantage to adding a hydraulic throwout system to a car that already has a terrific mechanical clutch linkage system.
