Quadrajet Carb
Old Jan 24, 2026 | 09:54 AM
Abedman's Avatar
Abedman
Cruising
Default Quadrajet Carb
On my Quadrajet, what is this piece that goes into the manifold and has hoses going to the carb? Because I swapped it over to my other motor but the manifold doesn’t have a hold for it to go into so I took it off. Is it fine to run with out it?
Old Jan 24, 2026 | 10:13 AM
MajD's Avatar
MajD
That looks like the choke tube that supplies air to the choke housing. Cool air is drawn in one end (usually the air cleaner housing) and heated as it passes through the tube on its way to the choke housing that contains the spring. As the car warms up, so does the air... causing the spring to move. You will need to replace the choke with an electric one. Hope this helps.
MajD
Old Jan 24, 2026 | 11:17 AM
Piersonpie's Avatar
Piersonpie
Here’s an article that talks about its function more, and what to do if you convert your choke to electric.
Old Jan 24, 2026 | 03:38 PM
MelWff's Avatar
MelWff
If you run without it the choke won't open.
Old Jan 24, 2026 | 05:53 PM
DWAVette's Avatar
DWAVette
I still run the hot air system.
I sent you a Private Message.
Please look read it when you get a chance.
Thanks.
Darryl
To Quadrajet Carb
