1980 Corvette - L48 - Electic Tachometer Reading Incorrectly
Old Feb 1, 2026 | 06:02 PM
jstobs's Avatar
jstobs
7th Gear
Default 1980 Corvette - L48 - Electic Tachometer Reading Incorrectly
Thanks in advance for any assistance provided. We're encountering a new issue after replacing the Tachometer board (On the back of the Tach) as well as the Printed Circuit Board for the Tachometer and Speedometer.
Currently, when using a timing gun, the car is idling at 800-900RPM, but the tachometer is showing 5000 RPM. No matter how many times we apply 12V and "Zero" the tachometer, it does not show anywhere near the correct RPM. We've done the zeroing in the car and just using a 12V and Ground from a Battery. We have replaced the Tach Filter and tried without the Tach Filter.
Any ideas to further diagnose our issue or solve the issue would be much appreciated.
Old Feb 1, 2026 | 07:10 PM
interpon's Avatar
interpon
Do not rule out another bad tach board. Where did u get it?
try this guy.
long lesson here
https://www.corvetteforum.com/forums...uestion-7.html
Old Feb 3, 2026 | 04:28 AM
hunt4cleanair's Avatar
hunt4cleanair
I've posted this article before but as interpon notes, there persists bad tach board makers out there. It offers some tips when replacing a tach circuit board.
Your Tach Says a Lot: Make Sure its Right!
To 1980 Corvette - L48 - Electic Tachometer Reading Incorrectly
