Hesitation at initial acceleration
Old Feb 9, 2026 | 11:23 AM
greaser2's Avatar
greaser2
Default Hesitation at initial acceleration
I have a 78 L82 auto, low miles very original thus it has Q-jet. I have done a carb rebuild. So overall it runs fine but I have a hesitation when: from stop push on pedal and for about a 1/2 sec it accelerates just fine, then for about a 1/2 second there is a hesitation, then it is fine again. I have already replaced the accel pump so expect that is not the issue. Thoughts?
Old Feb 9, 2026 | 12:00 PM
69L88's Avatar
69L88
Where did you buy the rebuild kit from?
Old Feb 9, 2026 | 01:07 PM
Piersonpie's Avatar
Piersonpie
Originally Posted by greaser2
So I checked it without vacuum last weekend, 17 degrees at idle (800rpm) and 37 degrees at 3000 rpm.
Ignition timing sounds good from your thread from last year. How much is your vacuum advance adding though? And at what vacuum level is it all in at versus how much the engine produces at idle?
Too much vacuum advance can cause a bog off idle. And if it needs more vacuum to be all in than what your engine produces it will cause a “wandering” idle, as well as other issues.
Old Feb 9, 2026 | 01:50 PM
greaser2's Avatar
greaser2
got it from cliff
Old Feb 9, 2026 | 03:35 PM
MelWff's Avatar
MelWff
When you rebuilt the carburetor did you use Cliffs book as a guide?
Did you check the accelerator pump check ball at the bottom of the pump casting?
Did you polish the pump chamber?
Do you have the pump arm on the inner hole?
Old Feb 9, 2026 | 06:31 PM
greaser2's Avatar
greaser2
I did not, I don’t recall such from speaking with Cliff
Old Feb 9, 2026 | 07:19 PM
MelWff's Avatar
MelWff
You may want to read this
https://www.themotorbookstore.com/how-to-rebuild-and-modify-rochester-quadrajet-carburetors.html?gad_source=1&gad_campai gnid=1806641261&gclid=CjwKCAiAqKbMBhBmEi wAZ3UboLxWjL8uRj_Eo7FlUgceLbNTJuRkL4t_SG iWV0TH2b6XNzHzHAi8jBoCytYQAvD_BwE
Old Feb 9, 2026 | 09:35 PM
greaser2's Avatar
greaser2
Book
thanks, I have a 79, is there something special about the 74?
Old Feb 9, 2026 | 10:41 PM
MelWff's Avatar
MelWff
Sorry, somehow the wrong link was attached. I meant to attach a link to Cliff's book.
Old Feb 10, 2026 | 11:33 AM
74contraption's Avatar
74contraption
I had a blown diaphragm in my vacuum advance that made it do that also,
Old Feb 13, 2026 | 09:02 AM
greaser2's Avatar
greaser2
I double checked the APT and it was at 2.75 turns out, moved to 4 out where the tip in is balanced and much better acceleration.
Old Feb 13, 2026 | 12:56 PM
MelWff's Avatar
MelWff
From Cliff Ruggles book
To Hesitation at initial acceleration
