That Top Left Nut
Old Feb 13, 2026 | 07:02 PM
AKjeff's Avatar
AKjeff
Default That Top Left Nut
On the pedal assembly...
I'm converting my autotragic to a manual.
I had to remove the gauge cluster to remove some other bracing under the dash so I could get a socket and extension on that nut, now the clutch pedal and linkage are in the way of getting a socket and extension on the nut.
It's the last thing remaining before I can move forward with reassembling the dash and installing the steering column, and it's fighting me.
Old Feb 13, 2026 | 07:11 PM
stingr69's Avatar
stingr69
Yes, and I feel your pain. It gets better and it is SO worth it.
Old Feb 13, 2026 | 07:15 PM
kanvasman's Avatar
kanvasman
You need to put a universal swivel extension between the socket and the extension. Not sure if what you are describing is the same as the bolt that holds the power booster to the firewall, but to get to that top nut, you need the universal swivel adapter. It is easy once you have that.
Old Feb 13, 2026 | 07:43 PM
AKjeff's Avatar
AKjeff
A large part of the issue I'm sure is the diameter of the pushrod. It's one of the fat aftermarket aluminum one's that I was given in a box of parts when a friend converted his to hydraulic.
I finally lay in the car and stuffed my arm up there to get the nut started, then couldn't get a socket and ratchet on it.
I may remove that pushrod, I have all the linkage assembled and would rather not take it apart again.
I can't see it giving me that much more room but it may be just enough to get an extension in there.
Old Feb 13, 2026 | 09:50 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
A 12 inch extension with a swivel socket.
Old Feb 13, 2026 | 10:37 PM
AKjeff's Avatar
AKjeff
I tried that, it's how I got the top right nut on and off.
I had to remove the clutch linkage to make room.
Old May 6, 2026 | 03:35 PM
AKjeff's Avatar
AKjeff
I was thinking about this post while driving my car today, it was worth it.
Old May 6, 2026 | 04:48 PM
drwet's Avatar
drwet
Congrats!
To That Top Left Nut
