Head swap pitfalls
My car came with a new crate motor. Vortec heads, roller block, high lift cam. 10:1 compression. dyno tested to 400 hp near redline. Bolted to a freshly rebuilt TH 350.
All fine and good, but I want a reliable cruiser with good low end torque that doesn’t shake like a magic fingers bed at idle.
I am going to install a milder cam and a TPI intake setup. I like TPI, I have a complete setup sitting in my garage, I’ve tuned memcals in the past, and that is what I am going to do.
I can keep the Vortec heads and buy a vortex lower manifold to fit them or I can remove the heads and put the money toward aluminum heads. What problems can I expect? Valve train gotcha’s? Pushrod lengths?
I’m guessing the block is a mid 90’s truck model. Thanks in advance.
I did a TPI swap a few years ago
https://www.corvetteforum.com/forums...ld-thread.html
I think the aftermarket TPI manifold base has the multi-angle accomodation, my Edelbrock TPI base does.
I also spoke with Ken at First TPI earlier in the month and he is taking orders for the First TPI intake. There's a 3 week lead time. He can machine baseplates in standard and Vortec ports, 8 or 12 bolt pattern.
Gen 1 sbc C4 got those heads mid-eighties thru 1991.
ZZ4 spec sheet/ GM: https://www.chevrolet.com/content/da...e-24502609.pdf
OTOH
both ZZ5 and ZZ6 Do Have Same aluminum heads with FastBurn combustion chambers; those Gen 1 sbc heads Not OE in any serial production passenger vehicle.
ZZ5 spec sheet/ GM: https://www.chevrolet.com/content/da...s-19301293.pdf
ZZ6 spec sheet/ GM: https://www.chevrolet.com/content/da...e-19419198.pdf
To the OP, I don't think I would have gotten that time trying to tune a GM ECM. Too many wonky tables and difficult to fine tune.
The switch to aluminum heads isn’t cost related. Yes the Vortec base is cheaper, but the $450 I would spend on it could instead go to the heads. The reason for the switch is better heat flow and lower risk of detonation vs iron heads. Same chamber design as the Vortecs. Same chamber volume. Lower cracking risk.
400 to 245 hp is not as big a drop as it first seems. The crate motor dyno tested to 418 hp and 400 ft-lbs @ 5600 rpm. 32 degree total timing. Carbureted. 308 hp and 450 ft - lbs @3600. That’s on a dyno open intake, open exhaust, no accessories. Maybe an electric water pump. Add on an air cleaner, exhaust, and accessories it’s maybe a respectable 425 ft-lbs @3600 rpm.
I drive closer to 3600 rpm than 5600.
A stock ‘91 L98 is 345 ft-lbs @3200 rpm. I’d expect a bump up with Vortec style heads.
Compare that with a 1995 LT1 with 340 ft-lbs @ 3600rpm. If frankenmotor accelerates my C3 like my C4 I’m happy. I can’t afford any more tickets anyway.
I will fab up an adjustable push rod to determine the length needed and report it back here.
A thicker gasket to lower compression is not a bad idea, but I would have to revert to non-Vortec style heads. Otherwise the decreased quench can cause detonation.
When spark rattle's right on the ragged-edge, an old 'restricted class' CT race trick is to sink some valves (slightly-increasing effective chamber volume).
You can also help assuage your risk-averse take on cast iron Vortec:
Have them Cryogenically treated. Many more metal-treat facilities now make that service available and for far less $ than before. Cryo truly toughens em up.
Large volume Head & Engine manufactures Now offer brand new iron Vortecs that have been Cryo-treated. That, specifically to help prevent cracking.
Similarly, Aluminum does also crack and there's help for that as well.
HIP (Hot Isostatic Pressing) is a proven treatment; often referred to as HIPPED or HIPPING.
