Crossfire problems or no?
Old Mar 4, 2026 | 06:45 PM
B in the Lowcntry's Avatar
B in the Lowcntry
2nd Gear
Default Crossfire problems or no?
Spun a bearing in my 82 Collector. The guys pulled the motor, replaced needed parts, got it all put back together. Went over to their shop to hear it run before they put it back in. After getting it back in it won’t stay running but maybe 3 seconds, then shuts off. Any ideas?
Old Mar 4, 2026 | 10:00 PM
Fast81's Avatar
Fast81
IF they forgot to plug in the oil pressure sender back by the dist, the CPU shuts the engine down if it doesnt see oil pressure at startup....................
Old Mar 5, 2026 | 03:50 PM
B in the Lowcntry
2nd Gear
Thank you sir. I will go find that connector and check to make sure its plugged in.
Old Mar 5, 2026 | 04:16 PM
jthornton's Avatar
jthornton
It's on the drivers side at the very back and has 3 prongs on it.
JT
To Crossfire problems or no?
