Should I replace these crossmember bushings?
Old Mar 5, 2026 | 08:39 PM
JohnnyJJ's Avatar
JohnnyJJ
Default Should I replace these crossmember bushings?
Still soft, but some cracks…replace or keep using? As far as I know, they are original to this 78 C3…
thanks for your input!
Old Mar 5, 2026 | 09:37 PM
interpon's Avatar
interpon
Leave them. No uv exposure…probably made from 70’s oil and whale gizzards compared to todays.
Old Mar 5, 2026 | 10:10 PM
JohnnyJJ's Avatar
JohnnyJJ
Thanks! Even the B17 dunk didn’t touch them…
Old Mar 6, 2026 | 09:22 AM
69L88's Avatar
69L88
Let sleeping dogs lie.
Old Mar 6, 2026 | 10:01 AM
GTR1999's Avatar
GTR1999
If you're just street driving and they are not loose, I would use them. Some of the new ones over the years had fitment issues I believe. I have the solid pucks for them as well that just bolt over the bushings to firm them up.
Old Mar 9, 2026 | 07:49 AM
cottoneg's Avatar
cottoneg
If you’re worried, they make aluminum dicks that can go under them to give added security. I’m sure someone here has a link.
Old Mar 10, 2026 | 03:43 PM
corvette74's Avatar
corvette74
Here is a pic of the aluminium disk.
Old Mar 11, 2026 | 08:01 AM
cottoneg's Avatar
cottoneg
Originally Posted by corvette74
Here is a pic of the aluminum disk.
That is what I was suggesting. It will add piece of mind. Plus the kits usually have an aluminum block for the differential nose.
Old Mar 11, 2026 | 09:17 AM
GTR1999's Avatar
GTR1999
Those come either with the solid snubber or without. I have all of Tom's kits here and they all have the snubber puck as well.
Old Mar 11, 2026 | 08:58 PM
rpoL98's Avatar
rpoL98
or, alternatively, welded steel spacers.
Old Mar 11, 2026 | 10:43 PM
ed427vette's Avatar
ed427vette
I have never heard of an original one of those failing. Ever.
But I have heard the replacements they sell now totally suck and do not fit right. But I never changed one so I don’t know for sure. I have taken the crossmembers out and put it back in without changing the bushings and it’s rock solid.
Just my experience.
To Should I replace these crossmember bushings?
