Temperature gauge
Old Mar 10, 2026 | 07:36 PM
Golferdad's Avatar
Golferdad
Default Temperature gauge
I just recently finished the interior and trying to get everything button up,all my gauges seem to work,except water temperature,which when I replaced the heads,I replaced the censor,but the size in the head was bigger,so had to add a coupling or maybe a reducer,to fit the censor,so is it possible that it’s just not reading it,or maybe the new one is bad,I have my old one that I took out,and can I just hook the wire up to the old one,not in the head,take a lighter and heat the end up,to see if the needle will move with the key switched on,or does it need to be grounded to the head,I’m pretty certain the old one was good when I changed heads. Thanks I hope I’m making sense.but,I guess my main thing is,does that end of the sensor,need to be all the way in the head,because mine isn’t.
Old Mar 10, 2026 | 08:59 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Just take the wire that goes to the sensor. Ground it to the head. What happens at the gauge? Swings all the way hot? Good wiring, bad sensor. Nothing? Bad wiring or guage.
have someone looking at the gauge for you. Don't want to ground it for to long.
Old Mar 10, 2026 | 09:04 PM
4-vettes's Avatar
4-vettes
The other question. It's not ideal to not have the sensor in the head. However just about any replacement sensor won't read correctly anyway. Your original sensor even if it's not completely in the head will still be touching hot coolant. Should still work.
Old Mar 10, 2026 | 09:30 PM
Golferdad's Avatar
Golferdad
Ok,thanks.
Old Mar 12, 2026 | 02:53 PM
SteveG75's Avatar
SteveG75
Replacement sensors are not accurate. There are many threads on this issue.
Old Mar 12, 2026 | 04:56 PM
ctmccloskey's Avatar
ctmccloskey
Be sure that your engine has a good functional Ground Strap and that it is properly grounded to the chassis.
Old Mar 12, 2026 | 05:50 PM
Rebelyell's Avatar
Rebelyell
You've already heard how replacement electrical senders/sensors are either not accurate or are wrong impedance to match OE C3 gages.
I suggest to you, that by using a reducer fitting to graft your larger sender to the new head's smaller hole, you may've created another aggravation.
It seems the sender should be constantly, continuously inserted into a moving liquid fluid stream. It also seems your sender may now be inserted into a somewhat stagnant environment; perhaps where air/steam pockets are as well.
No doubt: inaccuracy and wrong impedance are two different factors; and can exist either singularly OR, in this matter, in tandem as well. Cannot KNOW from afar.
If it were mine: I would first separately test and Verify the sender's Accuracy and Repeatability and that, in concert w/ OE gage, does produce a reasonably true representation of engine temps. Once that's resolved, and sender's proven accurate, I'd either enlarge & re-thread hole in head OR have that good sender turned down in a lathe and re-threaded to mate with hole in head. I'd re-position an accurate sender into a continuously moving stream of liquid coolant; directly into side of head per OE.
Old Mar 12, 2026 | 06:43 PM
kanvasman's Avatar
kanvasman
One other bit of info that I have discovered is not to use teflon tape as a thread sealant. It can mess up the ground.
Old Mar 12, 2026 | 07:00 PM
Rebelyell's Avatar
Rebelyell
I've heard that a lot.
And found that not so.
In practice, I've found the tapered pipe thread Teflon tape or sealant cannot & does not prevent the tapered threads from both cutting into one another and cutting through the Teflon / sealant.
I've also found that many OE GM and OE GM replacement senders deliver with a thread sealer on them; right out of the box. Typically a sort of brick-red color.
With that said, I cannot dismiss the possibility that Teflon tape may've interrupted ground path.
Old Mar 13, 2026 | 03:42 AM
4-vettes's Avatar
4-vettes
Highly unlikely that Teflon tape would interrupt the ground.
That's a myth.
Old Mar 13, 2026 | 08:45 AM
LT-1 1970's Avatar
LT-1 1970
I spent weeks dealing with that last summer. Probably have half dozen sensors laying around. Just couldn't find one to fit properly and that works with original gauge. Thinking for peace of mind I'll install another temp sender on the passenger side head to a gauge that I temporarily install where I can see it and compare readings for months. Then I'll just live it knowing what it really means. But I would sure like a real fix and be able to keep the original gauges like they are.
Watching.
Old Mar 24, 2026 | 09:53 AM
Golferdad's Avatar
Golferdad
Yep,I have about 4 sensors,none worked,so I just went to the parts place and bought one off the shelf,and even tested it in a pot of boiling water,and worked like a charm,so, put it in. So I had already drained the radiator,which I have to ask,the drain petcock at the bottom,I have a plastic plug with just a little nub on it which is hard to screw,and unscrew it,does everyone put a different or even longer plug in it,it’s hard to get pliers on it,I finally removed the plug yesterday,and it had a notch opening in it,never seen that type plug before,so guessing this type plug isn’t meant to actually be removed or loosening a lot to drain radiator,it also has a washer on it that is kind of loose,what made me remove the plug,I started putting anti freeze and noticed it dripping from plug,and it was tight,but thinking the washer wasn’t centered,or is stretched or something making not seal completely,wonder if a little sealant around it after I tightened up. Thanks
Old Mar 25, 2026 | 02:15 AM
4-vettes's Avatar
4-vettes
I removed the drain plug from my radiator and installed a sacrificial anode in its place to protect the aluminium radiator. No leaks. And I can drain by simply removing it.
To Temperature gauge
