aluminum heads
I have worked on one engine in 20 years that had AFR heads and it was a 406 in a 80' Vette....go figure.
I think the subliminal turn off is that they all use an 8mm valve stem....which takes away from the standardization of parts for us down and dirty low buck bohemian kind Lol.
Nothing wrong with the product except these ******** need to quit recommending 195cc heads for 350ci street engines....AFr 195 heads on 350's are as common as Edelbrock carbs on Q-Jet intakes with the adapter....Lol....
Seriously though there are a couple of threads on here over the years where folks were disappointed with the 195 Eliminator....and it was strictly that it was the wrong head for the application.....you have to move a LOT of air to make those heads happy....
Jebby
