LS2 Swap wiring help
Old Apr 17, 2026 | 06:55 PM
Grateful Dad's Avatar
Grateful Dad
Cruising
Default LS2 Swap wiring help
hello all
I am in the process of swapping in a 2006 LS2 from a manual Corvette going into a 1974. I am at the part where I am trying to take the stock wiring harness and convert it to a standalone use for my project. most of the information I am finding (LT1tech.com) is for truck versions of the platform, and or not specific enough for the harness I have. I am wondering if anyone here has the mapping/ pinouts for this engine and/ or has done a similar swap and knows where the skeletons lay. the issue I am having is the pinouts I am finding are close but not exact and I don't what to pull the wrong thing. additionally there is the sub harness that runs thru it that has 2 twisted pairs (1- yellow/grey, 1- yellow/black w/stripe) that run to what I think is the MAF/IAT terminal along with the 4 wires going back to the black Connector for the ECU. any help you can provide would be appreciated.
Old Apr 17, 2026 | 07:20 PM
M6Speed's Avatar
M6Speed
Cruising
Check out the website charm.li
It has had several diagrams and pinouts ive needed over the years
Old Apr 17, 2026 | 08:10 PM
peters220's Avatar
peters220
Look here. JP https://www.corvetteforum.com/forums...900d1486356178
To LS2 Swap wiring help
