Setting Idle Timing and Mixture
Old Apr 29, 2026 | 10:08 AM
jthornton's Avatar
jthornton
Default Setting Idle Timing and Mixture
Which is first?
Blueprint says 10° to 16° initial timing, how to tell what is the best setting?
Holley says adjust the idle mixture for the highest vacuum which I did on the old motor but I'll check it again on the new one.
JT
Old Apr 29, 2026 | 10:28 AM
Piersonpie's Avatar
Piersonpie
You have the Progression ignition distributor yes? That will definitely have a different setup sequence than a normal HEI, but if I had to bet I’d say 16 will give you a much stronger vacuum reading, and that’s what I’d go with.
Yes, ignition first, then carb adjustments.
Old Apr 29, 2026 | 11:31 AM
jthornton's Avatar
jthornton
Yes, ignition first, then carburetor adjustments.
Yes, I have the Progression Ignition distributor and I'll set the idle at 16° and go from there.
JT
To Setting Idle Timing and Mixture
