This info is not in the AIM!
Old Feb 22, 2003 | 08:53 PM
nada's Avatar
nada
Default This info is not in the AIM!
I have found that a 71 four speed 350 sb with air conditioning, has some assembly parts that aren't covered in the copy of the AIM I have. For instance, the windshield washer bag (and I do mean bag) is not in the AIM and, there is a big tank in the driver's side fender (behind the wheel and above the Fuel Vapor Canister). I guess it is there because of the air conditioner. Even the copper (fill at the radiator) radiator isn't in the book either. Although the 454 radiator is in the book. Has anybody else noticed this?
Old Feb 22, 2003 | 08:55 PM
JB's Avatar
JB
St. Jude Contributor
Default Re: This info is not in the AIM! (Rick Church)
I've occasionally had trouble finding stuff in the AIM, too. That tank on the driver's side is your vacuum reserve for the headlights, unless I'm misunderstanding what you're describing.
JB
[Modified by JB, 7:56 PM 2/22/2003]
Old Feb 22, 2003 | 10:12 PM
Rolling Thunder's Avatar
Rolling Thunder
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '03
Hope this helps.
Washer Bag see: UPC C60 sheet E4 lower left corner of page.
Tank Assy for vac see: UPC 12 sheet A14
Fill and supply tank for 350 see: UPC 13 sheet A3
Fill and supply tank for 454 w/air see: UPC C60 sheet D5
:cheers:
Dave
[Modified by Rolling Thunder, 9:51 PM 2/22/2003]
Old Feb 22, 2003 | 11:11 PM
nada's Avatar
nada
Default Re: This info is not in the AIM! (Rolling Thunder)
Thank you Mr. Dave! :cheers:
Old Feb 22, 2003 | 11:13 PM
Rolling Thunder
Cruise-In I Veteran
St. Jude Donor '03
Hey Rick, what's this junior member crap. You are a fixture around here. If you re-registered, contact Big Toe or one of the mods to get your old data swapped over. :cheers:
We gotta get together for a cup of coffee soon.
Dave
Old Feb 23, 2003 | 12:51 PM
mapman's Avatar
mapman
Default Re: This info is not in the AIM! (JB)
[QUOTE]I've occasionally had trouble finding stuff in the AIM, too. ......[QUOTE]
I found this Index to the A.I.M. to be helpful. This one is Eckler's pn 38156. You have to specify your year.
http://www.ecklers.com/product.asp?d...N0SM2EP37SAS4C
To This info is not in the AIM!
