Holley Help
Old May 20, 2026 | 11:29 AM
MelWff's Avatar
MelWff
Originally Posted by jthornton
I looked at the emissions sticker and my factory manual and can't find anywhere where it states to adjust the float level with the car idling in gear. I can't even find any mention of floats in my factory service manual.
For me adding an aftermarket carburetor I would follow the manufacturers instructions for setting the float level.
JT
Look at this sticker, lower left. This is before they put plugs to prevent adjustment of mixture.
Sticker
Old May 21, 2026 | 08:02 AM
bonesbrakr's Avatar
bonesbrakr
Originally Posted by 7t9l82
Some people have no sense of humor.
You cannot have a sense of humor on here. Some people actually ask for torque specs of the most mundane bolts. It is like they would loose points in NCRS judging if the correct torque is not used.
Others have no mechanical aptitude or common sense and will try doing what you suggest.
Old May 21, 2026 | 08:09 AM
7t9l82's Avatar
7t9l82
Sad but true.
And don't get me started on the NCRS.🤣
Old May 21, 2026 | 09:18 AM
ctmccloskey's Avatar
ctmccloskey
If we loose our sense of humor this site would be pretty boring sometimes. I appreciate the humor and frequently agree with it.
If someone really tried to adjust their engine while the manual transmission car is idling in gear. Maybe they should be driving a Honda and leave the old Corvettes to those with a bit of mechanical prowess. I thought it was a pretty funny joke...
When we discuss things with people seeking answers we take our job seriously. I separate humor from business carefully.
Life is Too short not to have some good Humor in it! Too Old too soon, too smart too late....
Old May 21, 2026 | 11:20 AM
jthornton's Avatar
jthornton
Sticker
Sticker does not say anywhere to adjust the mixture with the engine in gear.
With the engine at operating temperature, choke open, air cleaner installed, air condition off, parking brake on
  1. Set mixture...
  2. Set ignition timing...
  3. Adjust each mixture screw...
  4. If necessary readjust speed screw to specified idle rpm
Edit: There is no mention about adjusting the floats on the sticker.
JT
Old May 21, 2026 | 11:45 AM
jthornton's Avatar
jthornton
Originally Posted by bonesbrakr
You don't adjust a manual idling in gear. It will stall no matter what.
Well everyone knows you can't let the clutch up while adjusting the float level...
JT
Old May 21, 2026 | 12:46 PM
MelWff's Avatar
MelWff
  1. Set mixture...
JT
It clearly says Auto Trans in Drive, lower left
I NEVER stated anything about floats in DRIVE!
Old May 21, 2026 | 02:53 PM
jthornton's Avatar
jthornton
Move your vacuum advance hose from the ported position on the primary metering block to the manifold vacuum port on the throttle body front.
Also you have to check float level and adjust mixture screws in Drive, parking brake on, wheels chocked.
Seems like you did say to check the float level in Drive...
JT
Old May 21, 2026 | 02:54 PM
jthornton's Avatar
jthornton
And that would be for step 4 adjust idle speed if necessary.
JT
Old May 21, 2026 | 08:52 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Questions:
How big is the cam? Specs?
What is your vacuum reading both at idle? and In gear?
Old May 21, 2026 | 09:18 PM
MelWff's Avatar
MelWff
JT
I used the word AND, sorry I wasn't grammatically correct. Changed the statement to make separate sentences to prevent confusion. Thanks.
Old May 21, 2026 | 09:28 PM
MelWff's Avatar
MelWff
JT
You adjust idle speed and mixture together, not a separate process.
