Could be a lot of things. If it sways when you stomp on it it might be a rear control arm rusted through. I had to replace one once for that reason. The rear control arms are constructed of not much more than thick sheet metal in a box-like channel shape. In any case, it is worth the time to keep searching because something somewhere must be loose.
